New cylindrical batteries
Discussion in 'Gen 2 Prius Technical Discussion' started by Siber Pir8, Feb 14, 2019.
  1. Siber Pir8
    Siber Pir8 Junior Member
    55
    UK
    What's your take on these new kits that are popping up.
    Are they really that much better?
    HyMax Batteries
  2. JC91006
    JC91006 Senior Member
    16,777
    8,575
    better than what? they are not better than OEM
  3. Siber Pir8
    55
    UK
    That's what the blurb says, that they are more efficient than oem. Just wondered if anyone had actually and test figures to prove/disprove.
  4. JC91006
    16,777
    8,575
    They can make any claims they want. The OEM ones are proven to go 10 years without any maintenance. How does efficiency fit into that formula?
    What is a more efficient battery?
    Skibob likes this.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Where did you hear this blurb? The round battery guy here says his are the equal of the factory battery.
    Paging @2k1Toaster
    #5 Skibob, Feb 14, 2019
  6. dolj
    dolj Senior Member
    8,453
    4,292
    Wellington, New Zealand
    They look like CEBA batteries and they claim that they are rated at 8.0 Ah. Wouldn't be the same ones that @2k1Toaster tested and found to be only 3.5 Ah, would they?
  7. bisco
    52,035
    i prefer the triangular cells. even the ellipse are better
    strawbrad likes this.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are different types. The shapes themselves don't immediately make them inferior. I say mine are equal.
    Not sure how a battery can be "more efficient".
    Yes, ours are rated at 6.5Ah just like the factory Toyota modules. And they are tested and proven to be that. With an inking system you can mark whatever you want onto the top. I can sell you a 100Ah battery module if you want, but it won't actually be. Like the flash drives back in the day that were 1/4 of the claimed capacity.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Saw that the warranty is 3 year / 30k miles. That's what CEBA offers I believe. So if it quacks like a duck...
    Ewhitaker0020 likes this.
