240 volt chargers at home for 2018 Prime?
Discussion in 'Prime Technical Discussion' started by Rainydave, Feb 2, 2019.
  1. Rainydave
    Rainydave New Member
    Glendale, CA
    2018 Prius Prime
    I bought a slightly used 2018 Prime and see some 240 volt chargers that can be ordered. Is there a problem charging with a 20 Amp 240volt line. I may be able to hook up some type of surge protector or perhaps the plug has that internally. Thanks
  2. Tideland Prius
    16,589
    As opposed to 30A/40A lines? or 120V?
    Either way, you can charge at Level 2 (240V) if you wish (and take advantage of the shorter recharge time).
    Just ensure you have the proper cabling, if you're not going with a hardwired EVSE option.
    The stock cable is only rated for 120V/50Hz/12A
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Lets pretend you already have 240 where you can recharge. Look at the plug and match it to this list of NEMA standard Receptacles. (the R at the end, Plugs have a P at the end)
    There are very few styles of 120V receptacles, but tons of 240V. Once you know what you have, you can find an ESVE with that Plug.
    If you don't currently have a 240 volt receptacle near your car, choose one that ends -20 and does not start with L. (L stands for locking and if you forget and drive off, it will not come loose)
    I installed a NEMA 6-20 for my daughter's Prime, but it is no better or worse than the others.
    Many of these show you either the plug or the receptacle, some are just replacement cables.
    www.amazon.com/gp/search/ref=sr_nr_p_36_3?rnid=386419011&keywords=Level+2&rh=n%3A15684181%2Cn%3A15706941%2Cn%3A15707701%2Cn%3A7427413011%2Cn%3A7427415011%2Ck%3ALevel+2&qid=1549159632&low-price=150&high-price=300
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you've already got a line then it's just a matter of matching what you have.
    If you're running a new line, it is so incrementally small to put in wiring to support a full charger, you just should. We're wiring our garage with 2 separate 100A charger sub-panels, 1 on each side. The cost versus doing something like 30A breakers was barely noticeable.
  5. bisco
    52,219
    congrats and welcome!
    no problem at all. many have, and there are lots of good threads here.
    all the best!(y)
  6. Rainydave
    Glendale, CA
    2018 Prius Prime
    Thanks everyone. I have a 240v line right on the other side of the wall from where I park the cars. It was to service a heater that I now never use. I can disconnect it and put in a cut in box out the other side of the wall. It is a 20Amp circuit run with 12 gauge wire. I will look into the other threads also, Chears!
    I'm really liking my Prime after 3 days!
    Marine Ray likes this.
  7. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    Most of 240V chargers can do 30A... the Prime use only 16A Max when charging on 240V , so you should be ok with a 20A circuit. As a measure of precaution , i strongly recommend to find a charger that is limited or can be limited to 16A to make sure the circuit will not be overloaded. I have myself installed a 40 A breaker with 8 gauge wire and a 30A charging station , even if my car pull only 16A , i know ill be future proof or if i recharge someone else's car.
    benagi and 2k1Toaster like this.
  8. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    No. The PP draws 3.6 KW on 240 charge, so with P = I x V, that's 3600 = I * 240. Solve for I = 15 amps. That can be done on a 20 amp line.
  9. Rainydave
    Glendale, CA
    2018 Prius Prime
    That's what he said. Nice work with the math - Thanks jb appreciate the help!
    #9 Rainydave, Feb 14, 2019
  10. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    What exactly does the "brick" in the supplied 120V charging cord doing? I ASSUME it checks for ground or polarity errors. Does it do ANYTHING else besides that? If not, why couldn't one just remove the brick, and put a 240V plug on the end of the wire? This ASSUMES of course that you are using this cable to charge only at your home and have already guaranteed that the 240V outlet was installed correctly.
    I see all the several to many hundreds of $$ level 2 chargers for sale but I don't think they do anything useful since the car has the actual charger and the ability to charge on a schedule. No need for that in the "charging station". Seems like a lot of expense for nothing.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    "I don't think they do anything useful"
    Safety sensing. There are 5 wires in the J1772 plug, 3 are for charging, and two for safety sensing. The power wires are longer, so they are fully plugged in before the ESVE senses the Prime.
    I find the following protocols on Wikipedia keeping EVSEs safe:
    supply equipment signals presence of AC input power
    vehicle detects plug via proximity circuit (thus the vehicle can prevent driving away while connected) and can detect when latch is pressed in anticipation of plug removal.
    control pilot functions begin
    supply equipment detects plug-in electric vehicle (PEV)
    1. supply equipment indicates to PEV readiness to supply energy
    2. PEV ventilation requirements are determined
    3. supply equipment current capacity provided to PEV
    PEV commands energy flow
    PEV and supply equipment continuously monitor continuity of safety ground
    charge continues as determined by PEV
    charge may be interrupted by disconnecting the plug from the vehicle - SAE J1772 - Wikipedia
    So the EVSE (called supply equipment above) handshakes a lot with the vehicle being plugged in. (called PEV above)
    Folks ask a lot about safety in Snow or Rain; the J1772 plug is safe, but if the normal household plug is outside, it is way less safe. No protocols like above.
    jerrymildred likes this.
  12. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    OK, upon further reading and research, I see that the EVSE does have multiple and important functions as you listed.
    However near as I can tell, at least in the Prime and I believe most other PHEV/BEV, the "features" other than those you listed, provided by the charging stations that cost many, many hundred of dollars, are already in the car and are redundant. I can schedule charging start time in the car, don't need that ability in an expensive charging station. A portable 240V L2 cord and EVSE costing $180 or so does all that someone with a Prime needs since it's charger maxes out at 16A. For instance:
    You can buy something similar that charges at 32A for vehicles that can take higher amps (Amazon
    Morec EV charger Level 2 32 Amp for $366, instead of a ChargePoint 32A charging station for $630.
    illumiN8i likes this.
  13. Rainydave
    Glendale, CA
    2018 Prius Prime
    If I install a 32 amp charger with a 40 amp breaker, will the Prius Prime only accept 16 amps of juice from the charger? I definitely don't want to over amp the Prius. I don't see a 32 amp charger that can be dialed down to lower amp output.
    I just bought a Hyundai Kona Electric also and that battery is much bigger and could benefit from the faster 32 amp charger.
    Thanks
  14. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That isn't possible. The car only draws what it is designed to accept.
    Problems arise (not car related) when the charger itself (that external box) draws more than what the powerline is sized to deliver.
    bruceha_2000 likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    The amps will be limited by the car just like a light bulb only draws a half an amp or maybe one amp even when plugged into a 20 amp circuit. So a 32A EVSE will be loafing when feeding a 16A charger. I have a 16A EVSE, but my PiP only pulled about 9A. My Prime makes full use of that same EVSE. The one I have is just like the one shown by @bruceha_2000 in post #12 except the wall plug style.
  16. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    What happened to the 16A L2 portable charger I linked? And why can't I edit the post to put it back in?
  17. Tideland Prius
    16,589
    Post #12? I see the link to amazon.
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My links to Amazon all require a manual edit, I have never been sure why.
  19. jerrymildred
    11,517
    14,157
    Tampa, FL
    It's there. Is your ad blocker hiding it?
  20. CharlesH
    2,797
    1,164
    Roseville, CA
    I was fortunate that my electric utility had a rebate on the cost of the ChargePoint 32A charger that essentially covered its entire cost. All I had to pay for was the installation of a 240V outlet by an electrician.
