1. Kim White
    Kim White New Member
    Birmingham AL
    I just had the EGR valve replaced after noticeable skipping/missing in the engine of my 2010 Toyota Prius. I also had the spark plugs replaced since I have 125,000+ miles. Unfortunately the skipping is still there. My mechanic did not think the intake manifold needed to be replaced, but thought debris may be causing the issue. Has anyone had a similar problem? Suggestions?
    52,389
    welcome!
    yes, he should clean the intake manifold. check out all the 'nutsaboutbolts' video's on youtube.
  3. Mendel Leisk
    41,900
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    With 125K on the car, it's highly recommended to have your mechanic clean the intake manifold, throttle body, EGR Cooler, EGR pipe, and replace the PCV valve. The EGR valve has already been replaced. The EGR Cooler can clog up with soot over time causing air flow restrictions that can lead to other engine failures such as a blow head gasket.
    As @bisco and @Mendel Leisk have mentioned above, watch the @NutzAboutBolts videos that relate to the above items and share them with your mechanic. Good luck with your 2010! (y)
    NutzAboutBolts likes this.
  5. Kim White
    Birmingham AL
    Thanks! I just got off the phone and my mechanic said it was difficult to clean the intake manifold because the carbon hardens like cement and the manifold is plastic, is that true? I will check out the video and youtube for further info.
  6. Kim White
    Birmingham AL
    Thank you!
    Bay Stater likes this.
  7. Mendel Leisk
    41,900
    It's not that hard. I used mostly Brakleen spray. Some thin pipe cleaners are good for cleaning the narrow EGR passages (one at each intake). If you've watched the @NutzAboutBolts video you can see it's a bit stubborn but not bad.
  8. bisco
    52,389
    when you're paying someone else to do t, it's usually hard, and always expensive.:(
  9. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    ...and you're putting the life of your engine into someone else's hands... better check their work before closing everything up. (y)
    #9 Bgustafson, Apr 8, 2018
  10. bisco
    52,389
    agreed. unfortunately, many/most wouldn't know what to check. coming here is a great way to learn!
  11. HybridEcoPwr
    HybridEcoPwr New Member
    PoznaƄ
    2012 Prius+ MPV
    I own a 2012 Toyota Prius +. Just recently, after a long drive, I had something unusual going on with the vehicle while cruising at around 40mph in the city. When I kept the constant speed, the entire car started to rattle/shake. When I accelerated, the rattling disappeared. But when I went back to 40mph it started doing it again. And it is only doing it while driving on the gas engine. When it switches to electric, no rattling at 40mph. It is only happens on a warm engine. When cold, the rattling never happens. So, another Prius + owner tells me it is the EGR valve that needs to be either cleaned or replaced. I have about 200K miles on it. I just had the spark plugs replaced on it and no change at all. Do you all think that it is the EGR or something like a torsion vibration damper (it is what couples the gas engine with the transmission, I don't know the technical term for it)?
    Thanks!
  12. Mendel Leisk
    41,900
    With that miles, almost certainly near-clogged, which will be raising combustion chamber temperatures. Watch @NutzAboutBolts video #16 (EGR pipe cleaning) and check that out on your vehicle:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    This will give some idea of the condition of the rest of the system. You will want to clean both the intake manifold, and the egr valve/cooler (shown in other videos, same location).
    Toyota Canada has issued a "warranty enhancement program" (SOSH-W11-1A, dated May 2017), describing Exhaust Gas Recirculation (EGR) clogging. In it is the underlined comment "the majority of vehicles will not experience this condition". This is less credible than their mpg display.
    #12 Mendel Leisk, Feb 21, 2019
    Bay Stater, Patrick Wong, RMB and 2 others like this.
  13. Patrick Wong
    18,210
    6,513
    Did you receive this document and if so could you pls post? Thanks!
  14. Mendel Leisk
    41,900
    Something's acting up, getting mail from my phone to pc, so I'll just post jpg's from my phone for now. Will try to make up a pdf later.
    Note: this is from Toyota Canada.
    Addendum: pdf attached now:
    #14 Mendel Leisk, Feb 23, 2019
    Patrick Wong likes this.
  15. HybridEcoPwr
    PoznaƄ
    2012 Prius+ MPV
    Thanks, I will certainly take care of it. I will post my results after it is all done.
  16. Patrick Wong
    18,210
    6,513
    This mentions a sticking EGR valve, which is just a subset of the EGR system... what about the clogged intake manifold and EGR cooler, associated hoses, etc.
  17. Mendel Leisk
    41,900
  18. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    I must admit that you describe it exactly as it is to my car.
    I am a 2014 Prius + owner too, and I have exactly the same problem, but I did a EGR Valve cleaning, but not the intake manifold.
    Here are some pics with EGR Valve, before and after cleaning...
    Also, I must specify that I disassemble also the body of EGR valve... when I fit it back, I put the magnet at it;s highest position, but the motor was shaking massively... After I rotate the magnet on it's lower position, the engine works ok, but still this shaking after warm engine occurs...
    I plan to clean the Intake Manifold as soon as I can, and be back with details, meanwhile, maybe someone has new thoughts about the cause of this shaking...
    Simtronic and RMB like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Have you installed an oil catch can:whistle:?
    Another item to consider as you do all of the cleaning work;).
    Hope the pics of the cooler are with a lot of mileage on your Prius :).
    RMB likes this.
  20. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Thank you for your good words...
    I am not familiar with this oil catch can, actually this is first time I am hearing about it...
    I will do a good research and if it's suitable, I will do it...
    Until than, I need to continue with intake manifold cleaning, due to this shaking...
    I observed today, that if I start accelerating very heavy for few seconds, for a while the shaking dissapears...
    PS
    My Prius+ has now 184.000 km
    bisco and Raytheeagle like this.
