Quick Question
Discussion in 'Gen 2 Prius Technical Discussion' started by dirt657, Mar 10, 2019.
  1. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Driving down to San Diego. Of course the one time I don’t bring my Mini VCI cable and tools I get a red triangle. Had no other option other than to to into autozone to pull the codes and I have:
    P2601: coolant pump control circuit range/performance
    P0A93: Inverter cooling system performance
    My question is these codes are both for the inverter coolant pump, correct? I want to make sure one isn’t for the inverter and the other for the gas engine. I’m without tech stream driving home to the central coast from San Diego and I want to make sure I don’t have 2 pumps going bad. Thanks for your time as always, whoever you are. I hope your week end has been as pleasant as mine. -Cole
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    I believe the 2601 is for the heat storage pump at the storage tank. The 93 is normally associated with the inverter cooling pump behind the driver headlight. Odds are slim they both failed at the same time. More likely something in common with both has failed.
  3. bobodaclown
    bobodaclown Member
    216
    72
    My money is on the inverter cooling pump. Take off the fill lid and see if there's movement in the liquid.
  4. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I will when I get back to my place. Of course the CEL and the red triangle came off today driving back
