Prius 2010 Upper Radiator Hose?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Triparadox, Mar 20, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    I am planning on pouring down Blue Devil since I've got problem with head gasket that leads to coolant leaking into cylinder 1. Spent more than 2 hours trying to find any tutorial done with my car, no luck. Anybody knows where is the upper radiator hose since this car doesn't have radiator cap??
  2. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    Not a good idea - these types of products will clog your radiator, heater core and cause all sorts of problems.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,477
    Bay Area, California
    2019 Prius Prime
    @Joele3 local to us used this and it clogged his radiator system and plumbing :cool:.
    Maybe he’ll share his experience and if he’s do it again(y).
  4. Triparadox
    201
    108
    But it's even more of a bad idea that I have to spend $3,000 + on a $5,700 vehicle.
  5. Mendel Leisk
    38,313
    I think Toyota calls it the "No 2 Radiator Hose"? Have a look in the attachment.
    I'm in the don't-do-it camp too, btw.
    Raytheeagle likes this.
  6. The Critic
    3,193
    2,319
    CA
    How long do you need the car to last?
    The guy I linked in the other thread can probably do the job for under $1k, but you can’t get too picky...
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  8. Triparadox
    201
    108
    I'll continue to use this until the symptom appear again, then I might be changin the head gasket.
    Under $1,000 is still under my budget, so care to tell me which auto service? Also, are they careful with it?
  9. Triparadox
    201
    108
  10. Mendel Leisk
    38,313
    Aren't these stop-leak products also prone gum up the whole cooling system, heater core in the dash. Replacement of the latter is not a lot of fun.
  11. ChapmanF
    15,148
    Won't stay a $5,700 vehicle after having the sludge poured in ...
    ... so by that point it might not be a vehicle worth changing the head gasket on any more. Cost of changing out everything sludged could exceed value.
    Robert Holt likes this.
  12. Joele3
    Joele3 Active Member
    118
    189
    Bay Area
    I used K seal and it did buy me some time. If I were to trade my car in 18 months then I would use it. But if I was planning on keeping my car another 150k I would have not used the head gasket sealing fluid. It did buy me 33k miles. For some people that would be three years. I do a lot of driving so it was little over 14 months for me.
    I did more work included with the K seal. I just didn't add the K seal and drive it. I changed plugs, cleaned IM, EGR cooler cleaned/soaked/cursed at it. Installed an oil catch can which did catch some yellow jello looking stuff in it.
    Looking back I should have just did an engine swap when I first did all the work of taking off intake manifold I was about half way in. The process is scary looking but after i've done it, its not bad at all.
    RMB, The Critic and Raytheeagle like this.
  13. Raytheeagle
    11,251
    15,477
    2019 Prius Prime
    Between you, @leeb18c and @The Critic , the Bay Area is covered :).
    I guess we’ll see if I join the club or not(y).
    The Critic likes this.
  14. The Critic
    3,193
    2,319
    CA
    I’ll keep a gasket set and bolts in stock with your name on it.
    We can always replace your headgasket for “maintenance” so you can road trip in peace.
    RMB and Raytheeagle like this.
  15. Raytheeagle
    11,251
    15,477
    2019 Prius Prime
    We’ll see how much longer I have our 2010;).
    I was at @Pedal Logic ’s today and he thinks he knows someone that’d be interested in it and allow me to feed the Prime urge:).
    But time will tell and I’m not going to hold my breath (y).
  16. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    My neighbor just used blue devil. He has two beaters; one camry and one impala, both with head issues. Neither one worked. He sold both to the junkyard.
    He picked up a used g35 with 150k. :censored::censored::censored:
    I would try all OTHER avenues unless you plan on junking this vehicle if/when it doesn't work.
  17. Mendel Leisk
    38,313
    And the schmuck who buys it??
    Threej likes this.
  18. Triparadox
    201
    108
    Getting an over heating indicator today.. First time bringing it to a highway. 2 days before, I've been driving in a city for 54 miles. Just around 15 miles at highway and it appears.
  19. The Critic
    3,193
    2,319
    CA
    At this point, I would probably plan on installing a used engine, new radiator and possibly a heater core as well.
    In all honesty, that car is probably not worth repairing.
  20. Mendel Leisk
    38,313
    That quicky seal stuff sounds like putting sawdust in a transmission. But worse.
