2003 Gen 1 Prius Only Starts with OBDII Connected
Discussion in 'Generation 1 Prius Discussion' started by Betsy03Prius, Mar 20, 2019.
  1. Betsy03Prius
    Betsy03Prius New Member
    Missouri
    2003 Prius
    I have a 2003 Gen 1 Prius
    Mileage: ~161,000
    Battery: New From Toyota (3/2019)
    Spark plugs: replace 3/2019
    Coils: Old but seem fine
    MAF Sensor: New 12/2019, but determined that was not the issue for swapped for Original toyota MAF sensor
    Throttle body: cleaned 3/2019
    Fuses: Checked 3/2019, all good
    Relays: Haven't tested
    Disconnected and cleaned all the HV ECU (under passenger side carpet) terminals and the ECM (behind glove box) terminals with electrical cleaner
    OBDII Codes: P1636, P3002
    Repair: Toyota diagnostic testing and fuel line test. No issues ID'd and they could not get the codes to come on while they had it. Suggested new battery
    Issue: The car was having an intermittent starting problem. It would not go into ready ~20% of the time. Now it never starts unless I first clear the codes.
    HOWEVER, I realized today that IF codes are present and I turn the OBDII scanner "on" and then try to start (without clearing the codes) the car goes into ready. If the scanner is off it won't start. The car start if no codes are present (after clearing).
    Any ideas on what is causing my starting issues?
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    DTC Detecting Condition
    Wiring Diagram
    Steps 1 - 2
    INSPECTION PROCEDURE
    Nelsonprius likes this.
  3. greasemonkey007
    287
    107
    The battery ECU receives information of the AC ECU, system main relay connection signals, etc. the HV ECU, and stores DTC when an error is detected in the receives information.
    HINT: Check DTC of other ECUs and see whether any communication error of the HV ECU is stored or not. If HV communication errors are stored in then one ECU, replace the HV ECU.
    Wiring Diagram
    Steps 1 - 2
