185 tires instead of primes 195 tires?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by shimsha2005, Mar 29, 2019.
  1. shimsha2005
    shimsha2005 Junior Member
    C:\Toronto
    I have a 2006 prius i can't use any more and am getting rid of. Can i use my '06 's winter tires on my '18 prime car?
    185r65 15 to 195r65 15.
    I alsonhave brand new 185 all seasons that only went 15,000 km. Should i keep winter ones or all seasons? I was planning on keep winter ones.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I'd say you can use the smaller tires with no ill effects. This website will compare two tires and give the differences, Tyre Size Calculator. Visually it looks like this, Screen Shot 2019-03-29 at 7.07.11 AM.png What you have is a narrower and shorter tire. With a smaller circumference, it will cause the speedometer to read a higher speed than you are actually making. Combined with Toyota's already inaccurate speedometer, you'll see indicated speeds about 4 MPH high.
    jerrymildred likes this.
  3. shimsha2005
    C:\Toronto
    Whoa, that is very nice of you. Thank you.
  4. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Keep in mind it'll skew your odometer and MPG readings too, since they are distance-based. You also lose a little ground clearance. None of it is a huge deal, should be fine.
    And just to point it out, snow tires harden with age, and after a few years they really aren't any better than all-seasons.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Are your snow tires from ~2006 ? Meaning roughly 13 years old ?
    If not, when were they purchased & what's their remaining tread depth ?
    Rob43
    #5 Rob43, Mar 29, 2019
  6. shimsha2005
    C:\Toronto
    My prius is from 2006 ..but the winter tires are from 17 that went through two winters.
    Looks like I'm going through the route of mor using them both. I want my speedometer to be correct.
  7. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Haven't had my hands on a gen1 prius but the gen 2-3-4 were all "engineered" for a 25" diameter tire, which is the 195/65-15" tire, the 185/65-15" tire is 24.5" in diameter.
    If you run the 185/65-15" tires you either remember that when the speedometer says you're going 50mph, your really going 48mph, or you get a garmin gps and use it's speed readout.
    The gen2 came with 185/65-15 tires so owners either never knew the speedometer was incorrect or knew and compensated...mentally...or got a garmin.
    Remember, the 185/65-15...24.5" tires are going to reduce your miles per gallon, in my gen2 prius I was pleasently surprised when I put on 195/65-15...25" tires and my speedometer read correctly and my mpg increased.
    Anyway, for winters, if I had good 24.5" snow tires, I'd use them.
    And...if I had excellent 24.5" summer tires, I'd use them also.
  8. Mendel Leisk
    41,921
    Not sure what that means, but in-your-shoes I'd get the proper 195/65R15 size snow tires, sell the old ones.
  9. To add to this, the Prime's clearance is already low (for my taste), which is 4.8", and I'm always worried about opening the car door into a curb or snow bank, or turning into a sudden incline side street. Keep in mind, I'm coming from a Jeep 4x4, and then a Prius c (5.5" clearance, same as Model 3). Prime is 4.8"...
    With 185s you'll lose... is it 1/4 inch?
    Someone check my calculations,
    195/65/R15 section height is: 0.65 x 195 mm x (convert to inches) = 4.99"
    185/65/R15 section height is: 0.65 x 195 mm x (convert to inches) = 4.73"
    Difference is 0.26"
  10. Mendel Leisk
    41,921
    Yeah, the diff in width is 10 mm, and the width to depth ratio is .65 so:
    10*.65=6.5 (mm)
    About 1/4"
  11. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’ve run 185’s for about 5 years on a car requiring 195’s and have had absolutely no issue whatsoever.
    I have them because it saved $200 on a full set.
    Generally going down a tire size does absolutely nothing dangerous and is much safer than going up a size.
    So don’t overthink it, burn off your remaining rubber and replace it when it’s time
    jb in NE and FuelMiser like this.
  12. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    Put them on the rear and your speedo will be fine if that concerns you.
    Many cars read 5mph fast @ 65mph, my dads TDI did, it’s not anything important to worry about.
    #12 Rmay635703, Mar 30, 2019
  13. Mendel Leisk
    41,921
    I think most speedos read fast, by design. It's a safety measure.
  14. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    corrected
    I was thinking the car was slower than what the speedo read
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    All of our Gen IIs running the specified 185-65-15s read 2 MPH higher than reality in the 60 MPH range, 1 MPH higher at 30 MPH.
    I replaced the Goodyear (POS) Integrity tires on my '04 when it was 3 months old with Goodyear TripleTreds - 195's because at the time they didn't come in 185. Car ran fine, probably one of the few "all season" tires that did well in real snow. Most "all season" tires are good in all seasons that don't have snow.
    shimsha2005 likes this.
