(!) ABS VSC over 63 mph l suspect cheap replacement driveshaft.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by terramir, Mar 31, 2019.
  1. terramir
    terramir Member
    319
    51
    Los Angeles
    OK was told about 4 years ago there was a leak from the outer boot driveshaft passenger side. So I bought one well almost three years later I installed it. Well over 63 mph Christmas lights but in goes away after I stop the car and then drive city speeds.
    Now where should I go to have my old driveshaft checked in Los Angeles anybody know someone that will not bs me like the Stealership? Cause besides the grease being all brown and liquidy I dun see anything wrong looked on the autozone.com website moog has cv joints for 20 something dollars and we'll moog usually doesn't steer peeps wrong. But I guess I would need a decent machine shop to put it together.
    Got any advice, referrals cause " I can't drive 55 " lol. ;-)
    terramir
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Different size tires front vs rear, or different tread depths front vs rear? My first concern...
    Patrick Wong and davecook89t like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Have you checked out @Avi's Advanced Automotive ?
  4. Patrick Wong
    18,210
    6,514
    I agree that it is more likely there is a problem with one tire (wrong size, insufficient air pressure) or maybe a problem with a wheel speed sensor. I do not think a problem with the driveshaft would cause the speed-related symptoms described.
  5. terramir
    terramir Member
    319
    51
    Los Angeles
    Well I'll pump up the tires today and go for a test drive, but the drive shaft has to go either way I can hear the difference noisey while accelerating the whole engine sounds very different.
    terramir
  6. terramir
    terramir Member
    319
    51
    Los Angeles
    all tires equal pressure soon as I hit 65 or 63 both happened the light came on the dash won't go off till I stop and then go slow.
    my tires are all the same brand and model and well on each axle they dun differ much.
    and this didn't happen till I replaced the drive shaft. well I do not know about the speed sensor dun see how I could have damaged it replacing the drive shaft.
    and hints welcome on what to check.
    terramir
