Speedometer Accuracy
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by axle2152, Apr 16, 2019.
  1. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I've noticed this on both the 2016 Prius I had previously and noticed this on my 2018 Prime. The speedometer seems to be off by 4-5%, becomes more noticeable at higher speeds. Normally I would dismiss this as phones and GPS signals aren't always reliable but this is reproducible on every GPS device I have. Holds true on my phone, my dash cam and my Icom ID-4100 (amateur radio) which has GPS built in for D-STAR.
    The car shows I am traveling faster than the GPS will show, so if the speedometer shows 60 MPH the GPS devices will show 57-58 MPH. This gets larger when you're on interstates where the speed limit is 70 or more. If the speed limit is 70, speedometer will have to read 73 MPH. To pace with average traffic, say moving at 75 MPH, the car's speedometer would be up to 77-78 MPH.
    Not concerned with it so much on lower speeds but there is a concern I have, the big one being odometer reading. Assuming this is having the same effect on the odometer that means every 10,000 miles driven will show an extra 400 miles (at 4%) on the car. The other issue is the fuel economy the calculates which is also off, the car always reports better than actual gas mileage by about the same factor.
    Not trying to be picky, but at highway speeds the discrepancy is pretty noticeable and kind of annoying. I don't recall noticing other cars being off on their speedometers. The car has stock tires and wheels.
    So the question is, has anyone else noticed this problem with their Prius (4th gen) or Prime? I would assume it could be adjusted, but is it something that can be adjusted to be made accurate?
    TGrracie likes this.
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Speedometers intentionally read high.
    Probably for legal liability reasons.
    Multiple discussions exist on this issue.
    jerrymildred likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Yes, it's been noticed before. To my knowledge it cannot be adjusted. Just something you have to live with in these cars.
    axle2152 likes this.
  4. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Speedometers can't be accurate for legal reasons? :rolleyes:
    I couldn't find any threads that were relevant to the 4th gen/Prime.
  5. Prodigyplace
    12,678
    11,830
    Central Virginia
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This may not be a good assumption. Odometers are usually quite accurate and independent from the speedometer calibration. Since you are already using GPS to check speed, check your odometer as well.
    Mendel Leisk, fuzzy1 and jerrymildred like this.
  7. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Mendel Leisk, fuzzy1 and Prodigyplace like this.
  8. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    fwiw, a Gen 3 has the same "problem". It's not something I'm concerned about. I don't drive slower than anyone else and I don't drive faster either. In traffic, I follow it, when I'm alone on the road, I go what I feel is a safe amount of speed over the speed limit to neither get caught for speeding, nor get annoyed by going so slow when i'm the only one on the road. :)
  9. ETC(SS)
    7,352
    ^Oh?
    I'm curious about this, since my presumption was that the odometer used the same input as the speedometer - from the VSS sensor.
    Why would they be different and where does the odometer get this different input from?
    Priuses have always been inaccurate as far as their efficiency self-reporting is concerned AND coincidentally (wink-wink!) they've always overestimated their fuel efficiency for some "strange" reason. One presumes that speedometers will vary by a percentage point or two as you slowly grind off about 8/32" of tread from your tires, and usually tires are pretty central in determining speed over ground.
    Since passenger cars are usually not equipped with an inertial navigation system, and I'm "presuming" that they do not use satellite navigation to suss out the differences between speed through the air versus speed over ground, I'd be interested to see how the vehicle differentiates speed and accumulated distance(s) traveled, and what specific sensors they use for each.
    Of course, the next time you take a long trip with your car you can always go 'old school.' and set your trip odometer (or write down your main odometer reading) and use highway mile-markers to gauge your inaccuracies.
    DOT workers who plant those mile markers may not use differential GPS to put the sign in the EXACT spot, but one presumes that over...say....100 miles that they're going to be close enough for you to see if your VSS/odometer/speedometer is off by more than 2-3 percent.
    If you want repeatability?
    Do it again on your way home. :D
    Speedometer Scandal!
    #9 ETC(SS), Apr 16, 2019
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    AFAIK, the odometer and tripmeter both were dead on accurate when comparing to the mile markers along the interstates. Speedometer maybe off 2-3 mph at higher speed, but at lower speed it always shows the exactly the number shown on one of the roadside radar displaying your speed in 30-40 mph zones around my town.
    #10 Salamander_King, Apr 16, 2019
  11. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Exactly how hard would it be for the software that counts wheel revolutions to add 2 mph to the speed indicator and display an accurate odometer reading?
    I’d estimate about zero difficulty.
    fuzzy1 likes this.
  12. Prodigyplace
    12,678
    11,830
    Central Virginia
    If you set tire size / circumference in the software, yes. That is not a normal option for us though,
  13. Bob Comer
    708
    460
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes.
    Almost every new vehicle produced recently comes out that way......mostly on purpose, the be sure that it doesn't read LOW.
    It has been discussed here before at length.
    It is not REALLY a problem if you just learn to live with it.
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The odometer does get the same input, but then the speedometer software displays it with an offset. Intentionally, as this meets requirements in various jurisdictions. I have compared my odo to a GPS on a long trip, and they are quite close (a mile or so at a thousand).
    All of my recent cars (since 2006) have an optimistic speedometer. 2006 Miata 2 mph off at 60, corrected when I upsized the tires. VW TDI off by 2.5 mph, Prius off by 3 mph, Subaru Outback off by 1 mph.
    It's an annoyance rather than a problem. If I want to actually go 60 mph, I set the cruise at 63 and check my GPS for an accurate over-ground speed.
    In the later 2000 decade models, Honda had an odometer error that resulted in a class action lawsuit and extension of the 36K warranty to something closer to 39K (I don't recall the numbers). Automakers will be as accurate as possible in odometers, but have no compelling reason to make speedometers accurate (and have legal reasons to make them optimistic).
    ReDave likes this.
  16. ETC(SS)
    7,352
    Makes sense, but then this means that the folks in Aichi might not be as honest as I've been giving them credit for....and YES. that's sarcasm!
    If the odometer is accurate to within 0.01% then the fuel efficiency measurements should be as well.
    If they're not, in a car that prides itself in fuel efficiency, then that tells me much......
    jb in NE likes this.
  17. fuzzy1
    10,603
    Subaru too. Though neither my pre-lawsuit Subaru, nor Honda, displayed the alleged error. Both companies settled for approximately 2% warranty extensions, plus paying for some slightly out-of-earlier-warranty repairs. Plus enough to some class-action product liability lawyers to keep them wealthy.
    My post-lawsuit Subaru has an odometer that reads roughly 1.8% low. But its MPG display is pretty much right on.
    I don't remember Toyota getting hit with any similar odometer-warranty-fraud suit, but then I didn't own one at the time. My Prius odometer reads about 0.2-0.3% low.
  18. Mendel Leisk
    41,901
    When I had a scangauge plugged into the OBD port, it would display speed a little lower than speedo. This would I think confirm, that the car knows the more accurate speed, internally.
    jerrymildred, illumiN8i and fuzzy1 like this.
  19. fuzzy1
    10,603
    Then compare that OBD port speed reading to a GPS unit. I think mine matched when I checked long ago.
    Previous discussion indicated that on a Prius at least, the speed offset 'error' is added right at the dashboard display.
  20. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    I wonder if the speedometer is intentionally set too high for fuel economy reasons? For example if the EPA test cycle says something like drive 65mph for 10 minutes, there will be a slight savings if 65 on the speedometer means the car is actually going 63.
