Need for RPM and engine coolant temperature display on a Prius
Discussion in 'Gen 3 Prius Main Forum' started by hendji, Oct 22, 2014.
  1. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    I drive w/hybrid assistant app on most of the time, at least it has rpm and engine temp. My first mile of driving from cold soak is in a 25 mph zone so I keep an eye on the temp, when it’s warm enough I’ll push over 2k rpm on the engine.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Prius isn't traditional. It has a battery-pack and traction-motor to protect the gas-engine during the warming process. Prius has a specially adapted engine to reduce wear too.
    So, there is no need to monitor RPM.
  3. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
    adapted like what?
  4. john1701a
    12,817
    5,303
    58
    Rapid, low-stress warmup... The lighter pistons, the offset camshaft, the ultra-thin synthetic oil, the powerful starter/assist motor, the path for fluids & exhaust... They are all improvements upon the traditional approach.
  5. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Not everything I do is based on need. I like to see RPM.
    tvpierce likes this.
  6. ETC(SS)
    7,088
  7. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    I've seen people here recommend a 2009 gen 2 over a 2010 gen 3 more than often because of the knock start up (low-stress warm up) and clogging EGR (fluids & exhaust), it doesn't show improvement because of the recommendation to go with a previous generation.
  8. john1701a
    12,817
    5,303
    58
    That has nothing to do with my comparison to the traditional approach. I was not comparing generations.
  9. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  10. CR94
    CR94 Senior Member
    2,681
    1,161
    Northwestern S.C.
    What camshaft is not offset? Or did you mean cylinders offset relative to crankshaft? That is common nowadays.
    Funny isn't it, that all the supposed improvements you listed reside in a notoriously short-lived, high-maintenance engine?
    Grit likes this.
  11. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Yes, that's true within reason, but the engine protection isn't absolute. Flooring a cold engine is still a bad idea.
    A cold engine should be driven gently. A warm engine should be driven gently for mileage (unless high rpm is required for safety).
    Yes, the Prius can be driven quite well without a tachometer or coolant gauge, but I personally like more engine information.
    #51 BruceInOKC, May 15, 2019
    Mendel Leisk, CR94 and Grit like this.
  12. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    My ScanGauge II can read stock:
    CLSD LP OPEN LP Fuel System Loop Status
    MAP Manifold Absolute Pressure*
    BST Boost*
    MPG KPG MPL LHK KPL Miles Per Gallon Kilometers Per Gallon Miles Per Liter Liters Per 100Km Kilomteres Per Liter
    MPH KPH Miles Per Hour Kilometers Per Hour
    RPM Revolutions Per Minute^
    TPS Throttle Position Sensor
    FWT CWT Water Temperature^
    AVG Average Fuel Economy
    TFC Trip Fuel Cost
    CPM Cost Per Mile
    VLT Battery Voltage^
    FIA CIA Intake Air Temperature^
    FPR Fuel Pressure*
    GPH LPH Gallons Per Hour Liters Per Hour
    IGN Ignition Timing
    LOD Engine Loading
    HPR Horsepower*
    * I am not sure Toyota has this sensor, the Scangauge is only reporting sensors Toyota has.
    ^ I use these in my v.
    Gauges you can program the Scangauge II to know in a Gen 4:
  13. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    ...or maybe the engine protection is absolute, but I'm scared to test it out on a cold engine.
  14. CR94
    CR94 Senior Member
    2,681
    1,161
    Northwestern S.C.
    There are many others available, at least in Generation 3. Ones I usually or often watch are:
    Coolant temperature,
    Battery temperature,
    Engine speed,
    Battery current (erratic readings, 'tho),
    Voltage.of 12-v system.
    Others occasionally. I would like to delete some of the useless items.
  15. Mendel Leisk
    41,086
    Battery temp is an XGuage (requires you to program it in in), but yeah, very interesting to watch. Also battery fan speed: also an XGauge.
    Sadly, my constant ScanGuage hook up seemed to be causing Check Hybrid System issues (flakey OBD connector?), so I discontinued about 4 years back. So yeah: please Toyota, add an effing coolant temp gauge.
  16. pree_us
    pree_us Member
    64
    96
    Santa Clarita
    Here's a photo of my using the "basic" (aka free) Torque App on my aftermarket 9.0 Android HU . . . other monitoring gauges are available. I chose to keep it simple avoiding information overload.
    tvpierce and ETC(SS) like this.
  17. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    Nice.
    What data is "Load" based on?
  18. ghost2255
    ghost2255 Junior Member
    Poland
    I've mounted chinese meter from Aliexpress. Price is about 25$.
    It shows coolant temp, speed, revs and voltage. All at once.
    You can select what you want to display.
    I'm satisfied with this. Price is low, device is very useful
  19. abubin
    abubin Member
    188
    92
    Malaysia
    I find hybrid assistant to be most comprehensive with it's readings. It might not look "pretty" but if what you want are reading, it is readings you get.
    Another important feature that hybrid assistant and dr.prius provide is the HV fan speed control. I set it to 35c when I am driving because it will increase the fan speed for better cooling. In a climate that is always freaking hot here, it is an important feature because keeping the HV batteries temp low is important in preserving longer lifespan.
    Oh, BTW you do get to see the coolant temps if that's what you are after.
    GG707 and RMB like this.
  20. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Nothing is displayed for FPR on my SGII on my 2020 Prius Prime.
