Prius won’t start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Breanna, May 27, 2019.
  1. Breanna
    Breanna New Member
    Redwood City
    I have changed both o2 sensors and coolant pump as the codes popped up on the cancer. Car drove fine and the AC that had stopped working started up again. I got home parked my car smoked with the air going and then my car just died. I go to turn it on and it flashed where the gear guage is and wouldn’t turn on but the ACC (radio lights etc) turned on. So I checked my fuses some 15a fuses were blown out new ones in changed my 12v battery and go to turn it on it turned on and flashed the gas guage and the transmition guage. It wouldn’t reverse just rolled forward. Turned it off and back on and just flashed and turned off again. Not sure what’s going on and I don’t wanna sell my baby just yet!!! And I also don’t want to spend 300$ to get a specialist to check the computer just to tell me something small is the issue. I’m 24 in the Bay Area living is rough and I’m trying to do this as cost effective as possible. The video I uploaded is the first flashing lights. Now it just flashed squares where the transmission guage lights are. If anyone can help that’d be awesome. Like maybe my coolant wasn’t bled enough or was put in wrong or something
  2. Breanna
    Breanna New Member
    Redwood City
    I guess the video wouldn’t load. Go figure
  3. cyberpriusII
    1,155
    1,763
    Mars Hotel
    You cannot post a vid because you are a new member.
    Sorry, have no answers. I am not much of a car expert. Your description is a bit disjointed, but it may make perfect sense to someone that knows more than I know about the Prius.
    Also, it would probably get more notice if it were posted in the care/maintenance forum.
    Gen 2 Prius Care, Maintenance and Troubleshooting | PriusChat
    I will report it and see if the moderators agree or disagree.
    kris
  4. Mendel Leisk
    41,317
    You have to post 4~6 times, something like that, and then you can link a video.
  5. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Might be you've a failed inverter pump already.
    Get a code reader to retrieved any stored codes.
    That would help just in case.
    Replacing the fuse won't solved the problem.
    There should be a root cause.
    SFO and Raytheeagle like this.
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Which fuses did you replace? (name or #)
    What brand of 02 sensors did you use?
    Many mechanics will only install factory OEM 02 sensors (Denso brand).
