Intermittent problem starting
Discussion in 'Prius v Main Forum' started by JeffMorasco, May 24, 2019.
  1. JeffMorasco
    JeffMorasco Junior Member
    I have a 2015 PriusV with only 27,000 miles. It has suddenly stopped starting, and then after an indefinite period will start. The 12 volt battery seems fine and I have replaced the battery in the fob. The dealer has not seen this before and seems unable to figure it out. Has anyone else had this problem? Solution?
  2. Air_Boss
    Air_Boss Senior Member
    4,225
    1,188
    New Yawk
    By “stopped starting” do you mean that it will not initiate a start with the START button? Or it turns over but won’t run? Do you get any instrument panel indicators? Has anyone checked for retained diagnostic codes?
    Raytheeagle likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    "Seems fine" is not good enough. What exactly do you mean by that ? Has it been tested ??
    A VERY high percentage of "won't start" problems are resolved with a new 12 V battery or by fixing a loose main battery connection.
    Air_Boss likes this.
  4. bisco
    52,400
    check the brake switch
  5. mikefocke
    4,043
    1,839
    Sanford, NC
    And if the dealer can't solve the problem, ask them to call in the zone level experts. They will consult with the tech on the phone and help diagnose the problem.
    #5 mikefocke, May 24, 2019
  6. Mendel Leisk
    41,925
    Yeah, check:
    12 volt battery
    Brake switch (you need to be stepping on brake for engine to start, and that switch may be out of adjustment)
    Start Button (flakey?)
    Probably in that order.
  7. JeffMorasco
    By not starting, I meant that the whole starting sequence was not happening. The dealer had the vehicle twice, checked the battery on both occasions and did a check of all the computers on the second occasion. The both fob batteries proved low, and so we replaced them. That was good for one start then nothing.
    It was completely dead this morning. I tried jumping it with the recommended procedure with no luck. It did jump start from AAA. I think that the battery must be the culprit. I am having it pulled, replaced, and stored in case it proves to be something else. I don't know why the intermittent problems. Its failure would be considerably different than a conventional car where the engine would try to turn over slower and slower. This was just variable degrees of dead intermittently with a variety of irrelevant messages on the screen.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Which IS a very common symptom of a failing battery in a hybrid.
    Sometimes it is more "dead" than others.
    A really LOT of places don't really know how to test a battery.
    It needs to be done two or three times in a row with a short rest in between.
    AND......before you spend money on a battery, ALL of the main connections need to be checked, cleaned and tightened.
  9. JeffMorasco
    We tried all of the above, but eventually replaced the battery and it seems to be starting and running as per usual now. The intermittent part is news to me, but now it is old news. A new battery for the V is pricey by the way.
    bisco and Mendel Leisk like this.
  10. bisco
    52,400
    pricy for all pri
