Car won't start with key inserted into slot
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Jun 16, 2019.
  1. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    O7 prius. I have original key fob. Seems to have unprogrammed. Does not start when inserted into the slot. Is does beep when inserted but won't turn over at all.
  2. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Had a locksmith come out, and he was unable to reprogram the original key. It's like the slot doesn't recognize it being inserted in the slot
  3. bisco
    52,286
    how's the 12v health?
  4. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    The auxiliary battery in the back of the prius was replaced Jan 2nd.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Are you certain the RFID chip is actually in it?
    Fatmatt86 likes this.
  6. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Yeah, just did some research on the RFID chip and unfortunately there isn't one in my key fob l. There is a space for it but it is not present and is missing. Received the key fob from the original owner it must have got lost under their ownership. Is the RFID chip replaceable?
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Contact the previous owners. Hopefully they have the old case to transfer the RFID chip. If not, you will have to buy a NEW (100% virgin) fob from the dealer; new fobs come w/ a RFID chip. Then pay for a RESET (clears all past fobs from car) and RESEED (programs new fobs to work with the car) at the dealer.
    Price shop the RESET and RESEED procedure. Don't forget service discount coupons on dealer websites. Also AAA, AmEx, and Costco have dealer discount coupons too.
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Yep, you need a new key. I’m guessing it’s an SKS key as you were driving it without the RFID chip inside. Is this the Exon Valdez oil burner or did you get another Prius?
