How much should the 100k service cost?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brad K, Jun 26, 2019.
  1. Mendel Leisk
    38,260
    Not sure why, but I keep thinking it should cost $100K. :coffee:
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    May as well change the water pump if you are changing the thermostat ;).
    They are right by one another and the coolant will drained anyway(y).
    egn83b likes this.
  3. Brad K
    Brad K Member
    168
    53
    dealer quote for 100k service is $419
  4. Mendel Leisk
    38,260
    Do they itemize what they're going to do?
  5. Brad K
    Brad K Member
    168
    53
    I am sure they will. I may have them quote it per item too. And check with the 2 other local dealers
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    https://www.toyota.com/t3Portal/document/omms-s/T-MMS-13PriusC/pdf/2013_Toyota_Prius%20c_WMG_lr.pdf
    If it isn't in this manual, it isn't needed. Boils down to: Oil/filter change. Engine coolant change. Rotate tires.
    Check installation of driver’s floor mat
    Inspect and adjust all fluid levels
    Replace engine oil and oil filter 1
    Replace engine/inverter coolant 3
    Rotate tires
    Visually inspect brake linings/drums and brake pads/discs
    Additional Maintenance Items for Special Operating Conditions 2
    Driving on dirt roads or dusty roads:
    Inspect ball joints and dust covers Inspect drive shaft boots
    Inspect engine air filter
    Inspect steering linkage and boots
    Tighten nuts and bolts on chassis and body
    Driving while towing, using a car-top carrier, or heavy vehicle loading5 :
    1 Reset the oil replacement reminder light (“MAINT REQD”) or the message “OIL MAINTENANCE REQUIRED” on the multi-information display after maintenance at every 5,000 miles.
    2 Perform these service items only if you drive primarily under the conditions indicated.
    3 Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter. Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter. Refer to “Engine/Inverter Coolant” in the “Explanation of Maintenance Items” section in the back of this guide for more information.
    4 Refer to “Engine/Inverter Coolant” in the “Explanation of Maintenance Items” section in the back of this guide for more information.
    5 Not all vehicles are designed for towing. Refer to your Vehicle Owner’s Manual for details
    Brad K and Mendel Leisk like this.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    You don’t say where your located?
  8. Brad K
    Brad K Member
    168
    53
    All this for $419
  9. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    77
    Houston, TX
    2014 Prius c
    I dont have any warranty . I didnt buy any. Do I just go to any Toyota dealership for maintenanc ? I'm at 60,000 miles now
  10. bisco
    48,999
    you can, or you can look for any decent mech with lower prices.
  11. Kurt Weiske
    Kurt Weiske Active Member
    177
    130
    Do you really have to take off the wipers and the cladding to get to the plugs? I watched the YouTube video and didn't want to have to take the top end apart to get to the plugs.
    The person who designed a head with the plugs facing backwards should have been told to rotate them 90 degrees forwards!
  12. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    ~$300 seems a bit much for a coolant drain and fill.
  13. Brad K
    Brad K Member
    168
    53
    I agree, must be their money maker
  14. Mendel Leisk
    38,260
    Yup. The sand-pounder: maybe one more inch of clearance would have been enough. Cavalier engineering.
  15. Brad K
    Brad K Member
    168
    53
    a second local dealer quoted $210 for the same service
  16. pulltab
    pulltab Junior Member
    26
    Poway, CA
    2015 Prius c
    Had all the fluids changed, Oil Engine coolant, Inverter coolant, routine service here at a San Diego area dealership.. Not really a 100K service but everything was checked... 2 hours ...$400... Driving across Country -San Diego - Miami - Washington DC - take Route 66 back home.... all good
    Brad K and ztanos like this.
  17. Brad K
    Brad K Member
    168
    53
    $209 at the other dealership for 100k service but no inverter coolant replacement
