2005 Prius with E brake light on and won't leave neutral
Discussion in 'Newbie Forum' started by Steve Bishop, Jul 16, 2019.
  1. Steve Bishop
    Steve Bishop New Member
    Syracuse, NY
    I have the above situation. The car has been sitting since December and I just replaced the 12v battery. Any suggestions?
  2. PriusCamper
    PriusCamper Senior Member
    12,712
    5,137
    Pacific Northwest, USA
    Usually with these symptoms you have multiple warning lights on the dash and error codes stored in memory... Getting the error codes read is the first step.
  3. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    It’s not only the ebrake light, it’s also the you have a very large brake actuator assembly problem light. Is there a constant beep going on as well?
    mileage please.
    Is the car starting and charging the traction battery?
    Are you seeing the speedometer and gear lights?
    How long have you owned the car?
    #3 Skibob, Jul 16, 2019
  4. ChapmanF
    18,102
    It's not only the ebrake light, or the you have a very large brake actuator assembly problem light, it's also the you have one of about 198 other possible problems some of which are trivial and some of which are serious light.
    So, as always, it's the don't set anybody's hair on fire just yet but read the trouble codes light.
    Skibob likes this.
  5. Skibob
    2,912
    1,502
    Northern California
    I agree. That’s why l asked the other questions. 2005 that has not run since last December? Is it even starting?
