Oh how the mighty Bisco has fallen...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bisco, Jul 22, 2019.
  1. bisco
    52,263
    went for our usual drive this morning to a place we walk every day. charged the car, it started fine, nothing out of the ordinary that we noticed.
    4 mile drive, shut it down, walked for an hour, got back in, pressed power... nothing.
    no dash lights, no head lights, no hatch opening, tried the fob against the power button, nope.
    called triple a, guy was there in 15 minutes, put his meter on the battery, got a sad face on the screen :(
    then it said 4 volts. put the jump pack on the jump point and she fired right up. drove home and checked the voltage, 12.2
    charged the car again and 12.8, opened the driver door and 6 volts. i'm charging the 12v now, but i think something must have happened internally, can't understand why it shows 12.8 with no load.
    gonna do some testing before i go spend $200.
    so much for going for it, i thought for sure i'd get 10-12 years out of this one (yes, it's original). oh well, i said i would drive it until it dies, and i did, and it did.:cool:
    now my advice to others will change :rolleyes:
  2. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Check for loose battery cable connectors, but you know that.
  3. Mendel Leisk
    41,808
  4. bisco
    52,263
    i know, i know. there's a first time for everything.
    it only charged for an hour, slowly dropped from 13.6 to 12.05, put the cables back on, 8 volts.
    Potorap and Mendel Leisk like this.
  5. bisco
    52,263
    on the plus side, I've never been in there before, everything looks pristine. (even the battery:p)
    #5 bisco, Jul 22, 2019
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    If your battery was human:
    But you got your money's worth out of it. (y)
    mrlebop, Prius from Dad and bisco like this.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,496
    2,471
    Taylors, SC
    7 years on the 12 volt. It's the proverbial condition of a doornail.
    Mine, too, is over 7 years old and a candidate for giving up the ghost. Good luck.
    N.J.PRIUS, bisco and jerrymildred like this.
  8. bisco
    52,263
    thanks! conversing with the local dealer now. $211.35 plus tax
    asked them for the date code and can they put a charger on it
    N.J.PRIUS, iplug, WilDavis and 3 others like this.
  9. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Sorry to hear the demise of your OEM 12V. After reading your story, now I am definitely shopping for an emergency jump start battery pack to keep in my car. No warning and sudden death of Prius with a dead 12V scare me. Yeah, I have AAA, but would be nice to have a battery pack onboard all the time.
    #9 Salamander_King, Jul 22, 2019
  10. qettyz
    qettyz Active Member
    181
    206
    Finland
    All my failed car batteries and motorcycle batteries have been like that, full nice voltage after charge without load.
    Then add little load and voltage drops hard and capacity is like 0,1Ah
    Three car batteries, one motorcycle battery, not one did give any signs, just sudden death.
    Hugs for fallen!
    Montgomery, bisco and Salamander_King like this.
  11. farmecologist
    farmecologist Senior Member
    1,959
    1,799
    Southern MN
    You try a batteryminder? It has brought more than one battery of ours back from he dead. I'm a believer.
  12. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Sorry to hear about your battery. Good life for the battery. Here in Vegas we get 2 years. I’ve been shopping for one recently. I don’t like the price. Where did you get the new battery?
  13. Mendel Leisk
    41,808
    He says local dealer. That could be this:
    Or this??
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Given your past participation in battery threads on here.............
    NONE of that should surprise you.
  15. Georgina Rudkus
    3,496
    2,471
    Taylors, SC
    main photo.JPG pigtail on Prius v.JPG I have a battery minder pigtail and an EC5 jump pack directly wired to my 12 volt. I have attached a photo of the EC5.
    #15 Georgina Rudkus, Jul 22, 2019
    Montgomery and bisco like this.
  16. bisco
    52,263
    i emailed the closest dealer, who we have purchased a couple cars from. they are saying the battery comes fully charged, and there is no date code :cautious:
    i think i'll make some more calls tomorrow, no hurry.
    mrlebop and N.J.PRIUS like this.
  17. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    Wow! Who do you know? That's an amazing response time.
    Merkey and bisco like this.
  18. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    ...and that's why I change my 12VDCs at 5 years, proactively.
    ...and I still change my oil/filter at 5,000 miles, proactively.
  19. bisco
    52,263
    i was concerned, because when i called, i had to go through a bunch of menu's and finally got the recording: because of heavy call volume, please leave your number and we'll call you back, or hang on, and we'll answer your call in the order it came in,
    so they answered after about 5 minutes, and the lady wanted more info than a mortgage application.
    when we finally got through it, they gave me a 50 minute window, but the guy must have been in the area. he was driving a triple car, i was expecting a private tow truck.
  20. El Dobro
    El Dobro A Member
    7,088
    3,270
    I don't recall seeing any car batteries without a production date code stamped into it somewhere.
