Any good Hybrid/Prius shops in Florida?
Discussion in 'Gen 3 Prius Main Forum' started by Arsinek, Jul 22, 2019.
  1. Arsinek
    Arsinek Junior Member
    florida
    So I think my HV battery may have just died on me a couple days ago. The car will not drive, dash lit up like a Christmas tree and Check Hybrid System message.
    The car is a 2011 with 134533 miles.
    I called the two nearest Toyota dealerships, St. Augustine/Jacksonville Florida area, and both want over $2500 just for the battery, not installed.
    Does anyone know of any good hybrid/Prius shops in my area or in Florida?
    #1 Arsinek, Jul 22, 2019
    52,092
    tampa hybrids, probably too far. maybe todd knows someone though
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    Arsinek,
    The most important thing right now is to determine what your actual fault codes are to determine if it truly is a battery issue. If it is a HV battery problem, I may be able to help you out.
  4. bisco
    52,092
    how many miles on her?
  5. Arsinek
    florida
  6. bisco
    52,092
    test the 12v health
    check for movement in the inverter fluid reservoir.
    clean the hybrid battery cooling fan and intake grille
    have you had the recall done? this is not necessarily the battery
    chronon likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    @TMR-JWAP is really good. He knows the Prius well. And as he said, read the codes with a Prius-literate code reader to see if it really is the battery or something else in the hybrid system. As @bisco mentioned, there is Home - Tampa Hybrids Inc. over on my side of the state. He's terrific, but it's a bit of a drive.
  8. Arsinek
    florida
    Unfortunately whatever the issue is with mine its making it to where it will not drive.
    So tomorrow its getting towed to the local Toyota dealer, Beaver Toyota in St. Augustine FL.
    jerrymildred and bisco like this.
  9. Arsinek
    florida
    So here are my thoughts on the Prius...
    1. When the hybrid battery does go out the car should still be able to run on the gas engine
    2. Hybrid batteries should be as easy to remove and install as a battery on a cordless drill.
    chronon likes this.
  10. ASRDogman
    ASRDogman Senior Member
    7,648
    3,939
    EVERY car should be easy to work on. But they are not.
  11. Arsinek
    florida
    Ya but making it easy to swap out a Prius battery is something Toyota could easily do.
    chronon likes this.
  12. bisco
    52,092
    it could be easier, but looking at the videos, its not too hard.
    back up starter motor? hard hard could that be?
  13. Arsinek
    florida
    That's what I'm saying. Look at how easy it is now, and they didn't even intend for people to do it themselves. They could totally make those batteries swap-able.
    My problem is I'm literally in the process of moving and don't have the time or place to work on it myself. I don't feel like paying to have it towed to where I'm moving to. Course, that still might end up being the best option. If there car was where I'm moving I'd have plenty of space to work on it.
    chronon and bisco like this.
  14. ASRDogman
    7,648
    3,939
    Uhaul trailer? Where's it at? How far away do you have to go?
  15. jerrymildred
    11,517
    14,153
    Tampa, FL
    It's easier to replace the HV battery than the spark plugs, in my opinion. And I've done both. I thought the battery was a piece of cake considering that they only need to be accessed, on average, every 10-15 years.
    chronon likes this.
  16. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    i mean do you have any kind of scanner to get codes so you know more than just that dash is lit up ?
    That is about the right mileage for HV NiMh to start crapping out - yeah stay AWAY from the STEALERship , -- seriously, there's a reason they sit u down into a wifi area with free coffee , popcorn and home theatre ...
    there are some 'hybrid battery doctors' in tampa and sarasota , but BE CAREFUL and dont go the route i did with the 'fly by day' craigslist guy ...
    jerrymildred likes this.
  17. chronon
    601
    106
    I used to help people stranded, cars like chevy astrovans, ford minivans, are favorites of the heat for break down, i pull my scanguage out and can reset codes to get them going again, -- one time i pulled out a grinder to cut the rusty bolt holding the spare tire in back of a guy's borrowed pickup truck .. --- but i came to a chrysler 'labaron'? once and the battery is not under the hood, nor even under the back seat, it is tucked hidden away sumewhere behind a front quarter panel fender area and very unaccessable ... we couldnt even get the dash lights to come on ...
  18. chronon
    601
    106
    (and then he said he's moving and doesn't have time -- yeah bat check .. well voltmetter only tells you so much, you really need a load tester to determine 12v health - and its a SLA not a starter bat so is the load tester even going to give the kind of reading desired ( Amp Hours of drain, not Cold Cranking Amps of starting power)
    invertor fluid ez to check pump operating
    Cleaning the hybrid fan, requires the rear panel disassembly , prob. 1/2 hour min. and some (preferabbly) clutter and distraction free environment where parts and piece are going to get laid out ...
  19. chronon
    601
    106
    1. I beleive Honda hybrid has the ability to run without the hybrid battery - some of it's models are 'series' hybrids (not parallel like Prius)
    2. I think that was some of the thinking on board (design concepts for EV's), but suprisingly, it seems like all batteries on hybrids and electrics are tucked away mostly inaccessible, no ez swaps !!!
  20. bisco
    52,092
    then again, what has ever been easy on cars? engines and tranny's have always been the most difficult parts
