Energy Monitor - Hybrid battery bars
Discussion in 'Gen 3 Prius Main Forum' started by PelicanCat, Jul 23, 2019.
  1. PelicanCat
    PelicanCat New Member
    Hello,
    Going through a car wash, I had an error message come up requesting that I place the car in Park, it was in neutral. After getting through the wash, I put it in drive and the error went away. I noticed that the bars only went up to 6 not the full 8. I have just over 100K miles on the car. Should it still be going to the 8 bars? Does 6 bars mean that the hybrid battery is damaged? Thanks!
  2. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    The battery will recharge to normal as you drive, don't worry about it. As I understand, in neutral, the battery will not charge and if you have any accessories on they will use battery power ...the car knows this and asked you to put it into park.
  3. bisco
    52,278
    it sounds like you're okay, the battery doesn't always go to 8 bars.
    however, at the age of your battery, you risk running it dangerously low in a carwash that requires neutral.
    if you must, try to go in when the battery is fairly high, and don't use a/c.
    CR94 and jerrymildred like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    What @bisco said. (y)
    And welcome, BTW.
    The car washes that require you to be in neutral are a little risky if your traction battery is low, especially in hot weather with the A/C running.
  5. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    The EXACT same situation happened to me yesterday at the car wash. Nice to hear that it doesn't sound like a huge concern or that there's anything wrong with the battery.
