Rattle clunking sound at passenger side while engine running to charge the battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zakkie90, Jul 30, 2019.
  1. Zakkie90
    Zakkie90 New Member
    Boston
    Hi everybody,
    Do you know why there is loud and rattle sound when the gas engine have to run to charge the battery engine as you can see in the video? I just changed oil at Valvoline instant oil change yesterday and this sound appeared this morning. Maybe the technician did something wrong ?
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    You might check the oil dipstick to be sure it was properly filled with the correct amount of oil.
    Skibob and Raytheeagle like this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I can’t get the video to play but have you checked to see if someone stole your catalytic converters?
  4. bisco
    52,193
    never go to quickie oil change crooks
  5. Zakkie90
    Zakkie90 New Member
    Boston
    Thank you guys ! UPDATE : I came back to Valvoline and the technician said they didn't touch anything except oil change part. And I checked the dipstick and seem like its not overfilled.
    I haven't checked yet but if they did , there should be check engine turn on ? I didn't see any other problem than the clunk sound when the gas engine runs to charge the battery. Also, I have noticed that it did not happen when I drive more than 20miles/hours. It's wierd!
    I will bring it to my dealer tomorrow. Hope they won't give me a thousands $ bill.
    bisco and SFO like this.
  6. Zakkie90
    Zakkie90 New Member
    Boston
    updated: The problem is the loose heat shield ! I bring it to one of my technician that I trust eventually. He fixed in seconds ! Thank you guys !
