$4100 estimate from dealer for services needed with <50000 miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ripbc, May 4, 2019.
  1. bisco
    48,999
    what happens in vegas, stays in vegas
    i suspect the stealership read the o/p's post, and he's buried in a shallow grave in the desert on the outskirts of town...
    dig4dirt likes this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Heck there is probably more profit in that service then selling 10 cars!
  3. JC91006
    JC91006 Senior Member
    16,470
    8,383
    Dealers make money in finance and service. Not actual car sales
  4. Glee217
    Glee217 Junior Member
    Sf Cali
    I think it was a little loose but I didn’t think about retorquing it at that time since I was doing an oil change lol. But after the oil change I torque it to 18.5 ft lbs and will update if there is any leak.
  5. Mendel Leisk
    38,259
    Too: the oil filter torque is mainly to prevent it working itself loose. the seal is the O-ring, along the barrel. If the housing torque was a bit low it would not affect the O-ring seal.
    CR94 likes this.
  6. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Sometimes I hit the post button once and the two or three copies show up. Sorry!.
  7. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
  8. Glee217
    Sf Cali
    Update on 8/23 it was actually torqued higher than 18.5 ft lbs. I first marked the filter cap and the surrounding with whiteout and then loosened and re-torqued it to 18.5 ft lbs now and the whiteout on the filter cap is within a few cm to the whiteout on the surrounding.
    Also before re-torqued it I AGAIN see the same oil spray around the filter cap and ON the electrical connectors right above the filter cap/housing. So it seems over torquing the filter cap will make the oil leak as I see little drip out of the filter cap.
    So now I will update again in 2 weeks to see if it leaks again.
  9. Mendel Leisk
    38,259
    Those electrical connectors might be on oil pressure sensor, IIRC. And it's been known to leak too.
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Replace crook,oops, I mean dealer!
