240 line install complete and Rob's Cable Works
Discussion in 'Prime Plug-in Charging' started by jjs357, Aug 22, 2019.
  1. jjs357
    jjs357 Junior Member
    Near Philadelphia PA
    2020 Prius Prime
    Thanks to the advice posted here and @Rob43 for his pigtail, I have 240V charging enabled for my new 2020 Prius Prime. Media Gallery link embedded.
  2. jjs357
    2020 Prius Prime
  3. Bill Norton
    Bill Norton Senior Member
    2,146
    734
    MONW, Ks.
    So,,, you're running 240V through a 120v nema 5-15r outlet,, and a 120V extension cord,,, just lying there,,, on the ground,,,
    where anyone can come up and plug in a 120V device,, and with NO warning placards at all?
    Is this what you are doing?
    And you're telling the world about it?
  4. jjs357
    2020 Prius Prime
    I am sitting in my Town Home watching everything.
    I was thinking of adding some heat enabled wrap where Rob's pigtail connects to my extension.
    I guess I should attach some warning labels as well. Will do that!
    But this is not a community outlet -- this is my outlet running as an owner.
    And when there is no active use, the extension cord and Prius charger are disconnected and removed.
    The 240 box will be locked.
    Note: the box mounted on the wall is a standard 14-50 outdoor rated outlet. It is not 120V connector at the wall!
    Rob43 likes this.
  5. bisco
    51,892
    well done!(y)
    thanks rob!:p
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Looks great !
    Even though I shipped it out with a "High Voltage" sticker on your pigtail, it still might be a reasonable idea to either:
    1) Shrink wrap (as you said) both the pigtail end and the extension cord end connection points.
    OR
    2) Use 3 zip ties for both connection points, one loop goes around the base of each male & female plugs, the last zip tie connects both loops together in the middle. This way they can't easily be taken apart, then your main disconnect point is your 240v wall outlet. (just like everyone else in the world)
    I'm very glad to see you're up and running at 240 volts, charging up in 2 1/2 hours is fantastic !
    Rob43 :)
    Arctic_White and jjs357 like this.
  7. jjs357
    2020 Prius Prime
    For extra safety to control attempts to use the pigtail inappropriately, I taped the extension I use to reach the charger to the pigtail. Someone would need to exert a lot of force to disconnect the pigtail.
    I also bought some yellow caution tape that I will wrap around the charger electronics where it connects to the extension cord at my parking place.
    Won't stop a determined person from monkeying with the connections but they are impeded/warned about any attempt.
    And of course, I remove all connections when the car is not being actively charged.
    Bill Norton, Rob43 and bisco like this.
  8. bisco
    51,892
    smart thinking (y)
  9. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I just finished installing my 240V outlet as well with a new panel breaker with GFCI (13 & 14). I want to find a cradle to put the EVSE next to the outlet whilst the car is charging.
    jjs357 and Rob43 like this.
  10. jjs357
    2020 Prius Prime
    A small bungee cord through the EVSE holes, wrapped around the pole where the outlet is located might work if you remove the EVSE after it has been used to charge the Prius. That is what I am doing for my parking space connection. Using the bungee each time to mount the charger is quick and easy. One of my media photos shows this.
  11. bisco
    51,892
    that's what i do at public 120v outlets, usually works well
    Dael likes this.
  12. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    ok, maybe an addition to Chargepoint/Charge hub. Free 120 outlets but we need to keep it a secret :)
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    #13 JimboPalmer, Oct 20, 2019
    Bill Norton and Dael like this.
