Strut replacement needed or just boot?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by phelixdask8kat, Jul 19, 2019.
  1. phelixdask8kat
    phelixdask8kat New Member
    Aliso Viejo
    My left front strut is leaking and clicking. Do both sides need to be replaced?
  2. Matthew J Anderson
    Matthew J Anderson Junior Member
    Winnsboro, SC
    general rule of thumb.. replace both sides at the same time
    jb in NE likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It's not a requirement, but they are both the same age and the other side will be needing replacement soon. Do them together and one alignment covers them both. Do both, and you will need two alignments. In addition, this is one day in the shop vs two.
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OP,
    If you had two front tires that were both close to the end of their life and one of them experienced some sort of failure, would you buy one new tire only or would you buy two new tires ?
    Rob43
  5. frodoz737
    frodoz737 Top Wrench
    4,702
    2,500
    33
    Yes both...and replace your rear shocks too
