ring cleaner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by StarCaller, Sep 3, 2019.
  1. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    just wondering if nebody ever gave this cleaner a shot?
    amazon reviews from the boating community are not bad /
    Jim Swart, SFO and Grit like this.
  2. ASRDogman
    ASRDogman Senior Member
    7,549
    3,897
    If you put all 16 ounces it, it should really clean everything up, really fast! :)
    JUST KIDDING!
    I've never heard of it but there are several products out there for the same thing.
    Try it and see how it works.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The container says it treats UP TO 160 gallons of fuel...ignore that 1 ounce/10 gallon thing.....sounds to me like you can add as much as you want since " up to " means anywhere from 1 gallon to 160 gallons. I think ASR was right and didn't even realize it!! Just dump it in!!
    ASRDogman likes this.
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    I would add: anything that implies that it cleans rings (ie, "Ring Cleaner" but is obviously for cleaning upper cylinder (rings are NOT upper cylinder...) is to be doubted. I like the BG line of products; more expensive, but dedicated for particular tasks:
    Upper cylinder (injectors/valves) long term (10,000 miles): BG 44K
    Upper cylinder (injectors/valves) short term (add at fill up, or every other fill up) CF5 (on the order of Techron, Lucas...)
    Rings/crankcase flush (add just before draining for oil change, run ICE for 10 minutes in Maintenance Mode, drain and add new oil: EPR
    Engine Oil Supplement (add with new oil at oil change). Supports oil over extended drain intervals: MOA
    I've used these products on several cars (MANY miles) and they perform very well. All four available on eBay for 40-45 bucks. (NO affiliation). Can also get it at NAPA if you ask (it's under the counter...). ;)
    RMB, Raytheeagle and mikey_t like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Really ? Seriously ???
    NOT good advice. Not even close.
    :eek:
  6. Mendel Leisk
    41,341
    I'm thinking something you use by removing the spark plugs pour directly into the cylinder, let soak about a day, periodically hand cranking the engine a revolution or two: that's going to do something. A few ounces in a tank of gas, not so much.
    Tande, frodoz737 and GrGramps like this.
  7. Ed Beaty
    334
    311
    Salt Lake City
    It's something you put into the CRANKCASE, not the fuel (of course...). Running the to-be-changed oil with the BG EPR in it for 10 minutes is what does the deed. Hot oil with EPR in it coming up to the rings from below. That's the ticket!
    mikey_t and Raytheeagle like this.
  8. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Well, I thought that was obvious. Glad you picked up on it.....but not in the humor way I had expected......
    I'll try to do better next time...
  9. ASRDogman
    7,549
    3,897
    Humor? What the heck is that? Is that a new Toyota Hybrid?
    Grit likes this.
  10. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    cleans ring...that leads me to believe solvents may affect the engine's oil lubricity.
    garbage product.
  11. ASRDogman
    7,549
    3,897
    Doesn't it instruct that you put it in for "x" amount of time and let it idle? Then CHANGE the oil?
    So even if it does start to break down the oil, you're going to change it, so it wouldn't matter???
    Grit and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    And I thought based on the title we were going to get tips on cleaning our wedding rings:p.
    But I’ve used the BG Products suite before and they are great :).
    Helped keep our 2010’s oil consumption at a quart every 5-6k miles after 120k miles;).
    Another vote for BG stuff(y).
    RMB and Grit like this.
  13. Mendel Leisk
    41,341
    Added to oil IIRC?
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    • EPR prior to draining (idle for 10-15 minutes in maintenance mode)
    • MOA or Extended Life MOA to keep the oil basic (the MOA is good for 5k and the extended is good for 10k)
    • 44k once a year (or 15k miles)
    A good regimen and one I’ll continue on the Prime soon(y).
    mikey_t, Mendel Leisk and Grit like this.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    A maintenance item that non-married individuals like me can pass over.
    RMB and Raytheeagle like this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Maybe someday:p.
    RMB likes this.
  17. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    I've used the BG products as well. However, they are a bit expensive...but good stuff. (y)
    There is also a thread about someone having success with 'motor flush' and 'cataclean'. I'm going to give them a shot next time I change the oil.
    RMB, Peter123 and Raytheeagle like this.
  18. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    I use TC-W3 oil at 1 ounce per 5 gallons.
    The motor purrs like a kitten. If I forget to add during a fill-up the engine is noticeably louder in a few miles esp. during hard acceleration.
    No oil consumption @90k and counting.
    tacopyro, RMB, SFO and 1 other person like this.
  19. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Very cool. What’s your choice if engine oil and filter?
    RMB, Raytheeagle and mjoo like this.
  20. gliderman
    gliderman Active Member
    751
    225
    What was your oil consumption before you started adding TC-W3?
    mjoo likes this.
