Oily seepage on screw
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dom1172, Sep 4, 2019.
  1. dom1172
    dom1172 Member
    35
    32
    Sarasota, FL
    Was looking for something that I dropped in the engine bay tonight when I noticed seepage on a screw. I’m pretty good about keeping things clean so I was concerned about what could be “leaking” in that area. I highlighted the screw in one of the photos below. You really have to zoom in to see it, it’s not in an easy place to get a photo so this is the best I could do (actually easier to see in pic on phone for some reason), second pic is just to help reference location. Looking for feedback as to what could/would be seeping in that area.
    #1 dom1172, Sep 4, 2019
  2. Mendel Leisk
    41,341
    Looks to be at passenger side end of engine, looking down and to rear of engine, a bit past the engine mount.
    Hard to tell, could be timing chain cover (the whole end panel) has a slight leak, or oil pressure sensor: it's just round the back there IIRC.
    Taking off passenger side wheel, and a few of the wheel well back wall plastic panel fasteners, then prying back the panel, you might be able to see better where the leak starts.
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    My guess would be the oil pressure sensor, which is sort of on there hand-tight. There have been many threads however about seeping timing chain covers. Pull the panels and take a look before cleaning it up.
  4. ETC(SS)
    7,136
    Do you park on concrete?
    Any signs of oil under the car?
    Any work done on the car recently?
    I'm thinking timing chain cover - and no action required other than monitoring.
    Good Luck!
  5. bisco
    51,851
    if it's not dripping, i'd ignore it
  6. dom1172
    dom1172 Member
    35
    32
    Sarasota, FL
    Thanks for the responses. I park it in my garage at home. Concrete/slab floor. No work done recently on car/motor. NO oil on floor, though car HAS been "burning" some (drinks about a quart every 3k). It was actually worse (about a quart every 1.5k) but I took someone else's advice on here and tried BG EPR immediately before my last oil change and saw a noticeable decrease in consumption. Current mileage is 135k. I have not tried removing the wheel/fender but will. Tried a mirror tonight - do the new pics help at all? Thanks again!
    mikey_t likes this.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Early stages of a Timing Cover leak.
    The mileage is typical for when this starts to happen.
    mikey_t and Raytheeagle like this.
  8. Mendel Leisk
    41,341
    I just removed maybe a couple of the fasteners holding the plastic panel, the readily accessible ones. That's sufficient that you can then flex back the panel.
  9. dom1172
    dom1172 Member
    35
    32
    Sarasota, FL
    Thank you! That makes sense...I thought the timing chain on these cars was not a maintenance item, so would this just be something to live with until it becomes a problem? Appreciate all the guidance!
  10. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Oily seepage...reminds me of those Olestra warnings. :whistle: Yes...yes...I am a middle aged guy with the mind of a 13 year old.
    Seriously though, I think I have a similar problem on our 2010 liftback. It has around 120K on it. Oddly enough, no problems like that on onr 2012 Prius v (wagon) with around 150K.
  11. Mendel Leisk
    41,341
    Timing chain cover reseal is pretty involved. Dealerships have been charging $1700 range for this. Not sure what the book way is.
    Simplest is to leave engine in place, remove the engine mount, and I think the valve cover too. The flywheel and oil filter bracket too need to come off. Maybe the water pump too??
    Then pry it loose and remove. You for sure would want wheel off on that side, and that wheel well liner panel completely out of the way.
    After everything is clean and ready, there is a complex form-in-place gasket procedure, with very limited time since it sets up quick, and then about 25 bolts that are to go back on and be torqued, again in very short time.
    I would think the time parameters are near impossible, you should just work fast and be careful/thorough.
    I've got Repair Manual info, can post later.
    Bottom line though, if it is the cover, and minor leakage, just live with it?
    dom1172 and gliderman like this.
  12. The Critic
    3,193
    2,333
    CA
    At your mileage, you are probably a few years away from needing a head gasket job. Not all of the 2010's will suffer from this issue, but a number of them do.
    I would leave the seep alone. It is not worth addressing unless you feel like spending 6-8 hours of your Saturday doing the repair.
  13. Mendel Leisk
    41,341
    Repair Manual info attached. There's a dizzying number of bolts, various torque values, and the FIP gasket install diagram is a little nuts. I would think you apply the lateral dabs (at engine split lines) on the engine, and the rest just on the removed cover. I believe it's supposed to be applied and on by +3 minutes, and all bolts torqued by +15 minutes. There's a few O-rings and gaskets that it wouldn't hurt to replace, too, if you can figure out the part numbers.
    Still, it's a lot of work, too much if it's a minor leak.
  14. bisco
    51,851
    have you cleaned the egr circuit?
  15. dom1172
    dom1172 Member
    35
    32
    Sarasota, FL
  16. Mendel Leisk
    41,341
    With 135K it'll be getting along. Likely not terrible, but definitely worth doing.
    dom1172 likes this.
