EGR Cleaning: What did I get myself into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Jan 1, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Oxi Clean has cleaned up the EGR valve on my assembly. I take a small paint brush to work the crude out. Have not noticed any greying. Perhaps it's now clean enough.(y)
    mjoo and Raytheeagle like this.
  2. Bay Stater
    534
    771
    Central Mass
    Here is an update on the EGR cooler. I pushed the wire rod through all the ports again getting a lot of the crud out. Will continue with the Oxi Clean cycles.:whistle:
    scona, Grit, RMB and 4 others like this.
  3. Bay Stater
    534
    771
    Central Mass
    I paid $85 on eBay for the pleasure of cleaning up this EGR valve and cooler assembly:ROFLMAO:
    qettyz, m3pare, mjoo and 1 other person like this.
  4. Mendel Leisk
    41,457
    As far as I know, the cooler is 100% Stainless Steel. So no greying is to be expected. The valve on the other hand, is mostly aluminum: strong alkalines (such as Oxi) will start dulling/greying it.
    Yeah, it is not that hard cleaning your own, just takes time.
    mjoo and Bay Stater like this.
  5. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    For reference/comparison, some shots of the stock valve/cooler pulled from my 2010 @ 140k miles in April 2017. Swapped in valve/cooler from a 2015 salvage @ 18k miles, $115 shipped eBay. Eagles Ray and Jeff Honeywell assisted in a 4 1/2 hour blitz, including new water pump/t-stat.
    My Prius is down 4 quarts of oil 9000 miles after oil change
    #25 m.wynn, Jan 7, 2018
  6. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Same boat as you, plan to drive my prius to the ground. Gonna checkout some junk yards here soon for some to be had.
    Bay Stater, m3pare and Raytheeagle like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Lucky for you I have a spare that can be ready at some point :whistle:.
    All it’ll cost ya is a couple of cans of carb cleaner(y).
    Bay Stater, RMB, m3pare and 2 others like this.
  8. Mendel Leisk
    41,457
    If anybody doesn't mind having the car down for a day, you can just clean the one you've got, not that hard.
    Lightning Racer likes this.
  9. JC91006
    16,768
    8,565
    I finally started cleaning my 2010 today around 2pm. Took off a few easy parts and watched football while doing it. Removed egr pipe and realized it wasn't that bad. Cleaned it and put everything back.......back to football lol
  10. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    Did a clean egr change your fuel economy?
  11. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    If anyone is looking for quick EGR cooler swap in SF, I also can provide a clean EGR cooler as long as you return me your old one. :) I live near SF Zoo.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    How’s your head gasket doing?
    I guess as importan, which gets more driving these days: the Prius or the nice new Volt:whistle:?
    #32 Raytheeagle, Jan 11, 2018
    Bay Stater likes this.
  13. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I wonder if carb cleaner would be a better solution for cleaning the EGR valve? Brake cleaner is just a degreaser -- and this is not an oil/grease clean-up job. Carb cleaner and a tooth brush work like magic removing coked on crud in carbs, throttle bodies, and intakes.
  14. JC91006
    16,768
    8,565
    I used carb cleaner and it was fantastic, freed the carbon up in a few minutes
    Bay Stater, scona, mjoo and 1 other person like this.
  15. Bay Stater
    534
    771
    Central Mass
    I used break cleaner and oxi clean on the EGR Valve. Used an old toothbrush and small paint brush to agitate. Its pretty clean, but there is still some carbon crud in the bowl area. Haven't tried it yet, GumOut carburetor cleaner. :whistle:
    Raytheeagle, scona and Mendel Leisk like this.
  16. Mendel Leisk
    41,457
  17. padroo
    padroo Senior Member
    2,763
    2,252
    I have never done this job but has anyone ever tried oven cleaner to remove the carbon? Just curious.
    mjoo likes this.
  18. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Isn't oven cleaner destructive to aluminum?
    Pixel XL ?
  19. Mendel Leisk
    41,457
    Yeah but fine on the (stainless steel) cooler. As you know, obviously, it being your tip.
    I did try oven cleaner on the intake manifold, but it seemed ineffective. My take:
    EGR valve: brake cleaner
    Intake manifold: brake cleaner
    EGR cooler: brake cleaner with OxiClean follow up.
  20. padroo
    2,763
    2,252
    OK good enough for me.
    It seems people are doing this on high mileage cars with at least 100,000 miles on them. I kept the last Prius for 10 years and never did anything to the engine other than routine maintenance. I told my wife at our age there is no need to drive old cars.
    I don't plan of keeping this one that long and hopefully there will be advances in technology that will give me what I really want an all electric. I like having a car under warranty for traveling.
    Montgomery and Bay Stater like this.
