Limited vs XLE AWD side vents on front of bumper???
Discussion in 'Gen 4 Prius Main Forum' started by sorka, Sep 15, 2019.
  1. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    On the limited, they're just fake plastic inserts that are supposed to look like vents.
    On the XLE AWD-e, they look like something else entirely? Are they actual vents or lights?
    The Professor likes this.
  2. Mendel Leisk
    41,820
    Are you in the States?
    Pretty sure it's all just plastic dreck, mat-black plastic on some levels, some sorta lights on others. All the manufacturers are into contouring these fog/trim light locations to look like some sorta air intake, and it's all bs.
    Some do the same thing on the rear bumpers, too, so the imaginary air that comes in at the front has somewhere to exit.
    #2 Mendel Leisk, Sep 15, 2019
    AzWxGuy, alanclarkeau and krmcg like this.
  3. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Any idea what trim levels have actual lights? Cause if so I'm going to order them and replace the fake inserts or I'm going to order extra fake inserts and modify them with lights.
  4. Tideland Prius
    16,599
    Can’t confirm but AWD-e models have the silver plastic with thin LED light strip. (I say can’t confirm because I’m not sure if it’s just the XLE AWD-e or both the LE AWD-e and XLE AWD-e). Other models have the black plastic insert.
    alanclarkeau likes this.
  5. Mendel Leisk
    41,820
    I find the pdf brochures are often easiest to track down stuff like this. The back page with the fine-print about the levels. There should be a download link on the Toyota site.
    alanclarkeau and sorka like this.
  6. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    I wondered if that was the case but every shot I've seen of these don't show any actual light.
    What sucks is I would have chosen the AWD-e if I could have gotten it with the Limited but apparently in Canada, the XLE AWD there comes with the 11.6" screen while here in the US you have to get the Limited.
  7. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Thanks for that.
    Accent lights. So if you have the fogs, you also have the LED accents. What they heck is "stun factor"????
    How did they not include these in the top trim?
    RojaRosie and Mendel Leisk like this.
  8. Mendel Leisk
    41,820
    Love it. :ROFLMAO:
  9. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    In the parts catalog it's called a DRL.
    DAYTIME RUNNING LAMP OR ILLUMINATION LAMP. 2019 Toyota Prius HYBRID | Toyota
    I had to use a VIN from an actual XLE AWD in order to get it to show that part.
    Note, these are just the led lights that go into the trim. Still trying to figure out which part is the actual molding. There are two and it isn't clear which is the black insert vs the housing for the LED light.
    #9 sorka, Sep 15, 2019
    Mambo Dave and Mendel Leisk like this.
  10. krmcg
    2,592
    2,392
    Whittier, CA
    The Hybrid Pitstop in Buena Park California has used Japanese OEM fogs for sale. I got a set and they look NEW!
    #10 krmcg, Sep 15, 2019
  11. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    You link just goes to ebay.
  12. krmcg
    2,592
    2,392
    Whittier, CA
    RojaRosie likes this.
  13. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    The power connector for the accent lights is already right there on tab next to the insert on the inside, so this will be plug and play. I'll report back with he part numbers for the insert housings when I figure that out.
    Mambo Dave and Tideland Prius like this.
  14. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    The part numbers are:
    Lights:
    812B0-47020
    812A0-47020
    Insert housing:
    52713-47060
    52712-47060
    About $500 before shipping and tax from a discount online Toyota dealer.
    #14 sorka, Sep 15, 2019
  15. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    FYI, the connector from the inside of the bumper next to the fake insert:
    Tomek and Mendel Leisk like this.
  16. Tideland Prius
    16,599
    Note that there were differences in headlight housing for Touring vs. Non-Touring. The Touring had a white LED chevron parking light while the non-Touring used the turn signal as the amber parking light.
    In the photo above, it appears the AWD versions have a white LED above the headlights.
    Mambo Dave and alanclarkeau like this.
  17. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Looks like a wiring harness is needed. I think it's
    81935-47060
    but I'm not 100% certain. It appears the same harness also plugs into the fogs if you have them. I might add those later but it's a separate switch on the left stalk that the US Limited doesn't have so I don't know how I'd turn them on or off.
  18. Mendel Leisk
    41,820
    I think if you do fogs later you put a switch in one of the dash blanks?
  19. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    The entire switch assembly around the steering column ranges from $115 to $150 depending on which is the right one. Unfortunately the diagram does say so it'll take some dealer filtering on the vin but I'd go that route given it will likely be plug and play.
    That said, if the controllers default state is on (when the low beams are on) then I won't bother adding a switch.
    krmcg likes this.
  20. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    I called the Toyota dealer this morning that I placed the online order with. That is the correct wiring harness. They also said if I'd just called them I could have save the time researching as they get multiple daily orders from around the country for the exact same parts because folks are upgrading their limited trims to have the accents and fogs which the limited should have already had.
