Turtle uphill and Hybrid system overheat... please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shahzad Nayyar, Sep 19, 2019.
  1. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    Pakistan
    Not exactly daily. Excursion trips. Had a 2007 pri. Used to go up without any trouble. This 2015 initially went without any troubles but now is having this issue. And yes, B for descent
  2. Shahzad Nayyar
    94
    Pakistan
    IIRC it didnt go higher than 98 c
  3. Shahzad Nayyar
    94
    Pakistan
  4. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    Normal is 19XF, 98c is 208F. I drive uphill also to a dam here to go work out. My rpms are typically 1,700 at 20mph on sidewinding uphill roads. But once I get to parking spaces, and if traffic is slow On flat road, regen kicks in and once SOC is 50%, ICE temp is 202F. That is not good for my car but it doesn’t regen going steep uphill so no worry of overheating....yet.
    mjoo likes this.
  5. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    What was revving at 4755 rpm?
  6. Shahzad Nayyar
    94
    Pakistan
    Torque showed the rpm of inverter coolant pump
  7. Shahzad Nayyar
    94
    Pakistan
    Generally during normal driving condition i have not seen it go above 87 -90 c. What if the battery temp sensor is having an issue?
  8. bisco
    48,974
    maybe you need to bleed the inverter coolant loop
  9. Shahzad Nayyar
    94
    Pakistan
    Why do my sensors tell me that TB 1 & 2 are having a BBQ in the HV battery Screenshot_20190922-180041_Torque.jpeg
    #29 Shahzad Nayyar, Sep 22, 2019
  10. Mendel Leisk
    38,240
    TB's are the temperature sensors in the hybrid battery?? I know there are 3 of those.
  11. Shahzad Nayyar
    94
    Pakistan
    Yes.... but TB 1 max value 118 C and TB 2 max value 200 C????... its in celsius
    #31 Shahzad Nayyar, Sep 22, 2019
  12. Mendel Leisk
    38,240
    Something not making sense here? My guess: only sensor 1 is connected, and reading 43c. Sensor 2 and 3 are disconnected, and accordingly reading negative 51c??
    Greenteapri and mjoo like this.
  13. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Looks like a faulty sensor or an unconnected one.
    BTW, that fan looks a little Dusty. I would clean it out since you are having related issues.
  14. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    Cut wires that are bouncing against a ground? There's no way a NiMH battery could withstand those high temps.
    Pixel XL ?
    CR94 likes this.
  15. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    With car and engine off - what's the voltage of the 12V battery?
    Pixel XL ?
  16. Shahzad Nayyar
    94
    Pakistan
    I thinkbthe fluctuation on torque is due to the obd 2 adapter. I usually check the highest value
  17. Shahzad Nayyar
    94
    Pakistan
    Will have a look at that
    12V turned out fine
    #37 Shahzad Nayyar, Sep 23, 2019
  18. bisco
    48,974
    that an odd voltage (n)
    mjoo likes this.
  19. Shahzad Nayyar
    94
    Pakistan
    So new development. I got my prius to my trusteorthy mechanic. The guy checked everything.... block voltages, temperatures and everything. Final decision he opened the battery fan and it was this much clogged. It works apparently fine for motorways and city driving but once i need max cooling of battery on hill drive, it couldnt perform its job as required. Got the fan cleaned. Will test later.
  20. bisco
    48,974
    doesn't look too bad, but it's hard to see well. see posts #3-6 and #14
    do you carry any pets?
    #40 bisco, Sep 26, 2019
