Hi I need to remove the plastic cover of the exterior rearview mirrors of my 2006 Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kako, Jul 30, 2013.
  1. Kako
    Kako Junior Member
    Does anyone knows how to do this properly without breaking it ? Let me know. Thanks
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    You need to remove the mirror first, then you can remove the cover.
    You will need a moulding remover to detach the four claws that hold the mirror onto the housing.
    Disconnect the two electrical connectors and remove the mirror from the housing.
    Once you get the mirror removed, detach the six claws which hold the cover on the housing.
    Done.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    ^^No - waaaaay too much work.
    If your only looking to remove the 'cover' that hides the mirror motor and housing - I used a very small flathead screwdriver and just popped the cover off. Done it multiple times, never broke any tabs.
    Did it when I did my puddle lights and PlastiDip'd the side mirror covers
  4. jadziasman
    1,355
    487
    District 6
    It might help the OP out if you posted a photo of the opposite side of the covers (if you have it)
    so he can see where the tabs are.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Don't have any pictures myself of the back side but this is the image that helped me of a G3
  6. artrockets
    artrockets Member
    39
    39
    #6 artrockets, Oct 9, 2019
  7. artrockets
    artrockets Member
    39
    39
  8. ChapmanF
    15,630
    Without arguing whether it's possible to do without popping the glass out, I'll just say: I pop the glass out. It's easy, it's made to pop out, and the claws you push on to free the color cover are right there to push on after you do.
  9. artrockets
    artrockets Member
    39
    39
    My pics are all messed up.. you can get in above the mirror into the cowling(between mirror and cowling) with a thin flat blade and release the 2 clips that hold in the middle..
    2 clips in the middle and 3 hooks along the bottom..
    maybe adjust your mirror either full down or up and se if you can see back there with a flashlight.. Ill try and get my pics working..
  10. artrockets
    artrockets Member
    39
    39
    I put some bits of green tape on the 2 bits you have to hit to release the mirror...
