Why the Camry Hybrid in one picture
Discussion in 'Toyota Hybrids and EVs' started by CamryDriver, Oct 13, 2019.
  1. mikefocke
    4,040
    1,839
    Sanford, NC
    When I shop for a vehicle, I shop for different things that it must have when there are different drivers and thus different expectations.
    Mine can have lots of "gotta learn" controls, for example. Hers none. One of them must carry cargo. Mine has bags and bags of trash waiting to go to the dump tomorrow. Mine should be higher off the ground, hers has to be capable of lower yourself into the seat entry. Mine could be an EV, hers not a chance. Etc.
    There is a right tool for the job. And no one tool is right for everyone. And even my/our next choice may turn out to be wrong.
    Trollbait likes this.
    52,386
    my head hurts (n)
    alanclarkeau likes this.
  3. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Having rented many Camrys, I’d always agree- that’s a much nicer car for many circumstances.
    But regarding the Yaris you rented- was it a 2020? This new model is a heck of a lot nicer than the previous generation. It’s still no Camry, but it’s come up well...
  4. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    No it has been a few years.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Those old ones weren't real nice - the absolute worst clutch I've ever used for a start.
    The new one just announced should be good.
  6. Tideland Prius
    16,615
    I’ll go check it out if it’s unlocked ;)
  7. CamryDriver
    541
    391
    Arkansas
    I expect you are correct.
    That said it is nice to have the power available. Last weekend I was doing Sunday errands puttering around town mostly using very few horsepower and getting 55 to 65 MPG. Once and only once a stoplight turned yellow and it was either slam on the brakes or gun it... In my 93 horsepower Civic I'd have needed to hit the brakes but with the Camry, woosh, down the road, nice.
    Tideland Prius likes this.
  8. fuzzy1
    10,603
    Why? Was that yellow light too short?
    I never gun a yellow light in any vehicle. The timings are supposed to allow for reasonable non-panic stops.
    #48 fuzzy1, Oct 19, 2019
  9. Trollbait
    12,679
    Pennsylvania's seem to be half the length of other states.
  10. bisco
    52,386
    around here its hit or miss. i hate slamming my brakes, almost as much as i hate getting slammed
  11. fuzzy1
    10,603
    Lights that are shorter than federal requirements or US-DOT guidelines should be challenged in court. Numerous cities have been forced to refund tickets from automated traffic light cameras after victims found the yellow light timing to be shortened for profit reasons, or shorter than nearby unmonitored lights, or even shorter than legal minimums.
    Yellow light timing should allow at least 1 second of response time plus a braking rate of 10 ft/sec^2, or about one-third of a 'g'. This rate is certainly firm braking, but not the hard panic braking that can be (nearly) 1 'g' with good rubber on good dry pavement. Some guidelines suggest a bit more time than this.
    And in 'restrictive yellow' states, where drivers must be out of the intersection before the light turns red, the timing should also include enough time to clear the intersection without 'gunning it'. This extra adder doesn't apply to 'permissive yellow' states, where drivers cannot enter on yellow but are not required to be clear of the intersection before the red.
    Drivers should never be put in a 'dilemma zone' where they can neither safely and reasonably stop in time, nor legally go through without gunning it. When offending intersections are found, they should be challenged.
    #51 fuzzy1, Oct 19, 2019
