Problem with the AC
Discussion in 'Gen 3 Prius Accessories and Modifications' started by markjosh51, Oct 26, 2019.
  1. markjosh51
    markjosh51 Junior Member
    42
    North Hollywood
    I hope that someone might have experience this problem. I have a 2014 Prius two. Every time I turn on the ac the air flow gets really weak. It feels like it wants to turn off. I have also noticed that when it does this the air temperature goes from cold to warm. Then in about three minutes the air flow returns back to full and the air temperature gets cold again. This happens every 10 minutes. I changed the cabin filter hoping that the problem was fixed but it still does. I don’t hear any noises and my car drives fine when it does it. Has anyone experienced this?
  2. PriusCamper
    PriusCamper Senior Member
    13,407
    5,413
    Pacific Northwest, USA
    @lech auto air conditionin is our PriusChat expert on these systems... Message him, or maybe he'll notice being mentioned before you reach out to him?
  3. bisco
    52,784
    welcome!
    how many miles on her?
  4. markjosh51
    42
    North Hollywood
  5. lech auto air conditionin
    830
    606
    261
    san francisco
    I got to say on the Prius I have not experienced this one yet but I’m here in San Francisco in a mild climate.
    Every 10 minutes sounds like a pretty fast cycle time for the problem that I’m about to mention but I might as well give a shot in the dark and see what comes up.
    Next time this problem happens if the blower sounds like it’s still running but the airflow starts slowly getting weaker well this problem still exist open the hood of the car locate the large suction line the cold line does it look like there’s some frost on it you won’t be able to see this in all weather conditions depending on temperature and humidity.
    I was just thinking of ice forming on the fence plugging up the condenser stopping airflow but the blower keeps blowing.
    But if it’s the actual blower slowing down and coming to a crawl that’s a different story somebody else may be able to chime in on that one if they have come across that I have not on a Prius.
    PriusCamper likes this.
  6. bisco
    52,784
    there could be a blower problem, but i don't understand why the air would get warmer.
    the fan speed does correlate to compressor speed though, iirc
  7. markjosh51
    42
    North Hollywood
    I checked the fans to see if they were spinning and they were. I also checked the metal pole and i didn’t see any frozen ice. Maybe it could be the compressor or low refrigerate.
  8. markjosh51
    42
    North Hollywood
  9. bisco
    52,784
    so pull out the cabin filter and watch the fan when the airflow slows.
    does the air get less cool as flow slows, or does it actually become as warm as ambient?
  10. markjosh51
    42
    North Hollywood
    I think I may have found the problem. The fan did looked like it slowed down just a little bit.
  11. bisco
    52,784
  12. markjosh51
    42
    North Hollywood
    But I don’t know if the temperature is caused by this. I guess I will replace it an see what happens.
