Wrecked my prius.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Oct 29, 2019.
  1. Prius92
    Prius92 Member
    376
    95
    Iowa
    So as the title says, I was involved in a minor wreck in my Prius. Oddly enough, all it did to the Camry I rear-ended was put about an 10" wide dent in the rear bumper, while it did much more to my car. I was going about 10 mph.
    Here is the pic the day of the accident.
    Good news: no airbag deployment, the windshield is fine, and so is the tiny windows near the doors.
    Bad news: I'm going to have to have a body shop fix a few pieces of bent metal that is not removeable.
    The aluminum crash bar is going to get replaced as it was bent somewhat in the wreck. It can be had new rather cheap. It also pushed the rail in about 1/4".
    It pushed the pillar in slightly near the windshield, but I can't see where anything else buckled, unless it was like that before.
    This is the only piece of non-replaceable metal that got bent.
    It sent the center beam into the A/C condenser and poked a hole in it. I've already removed it and capped the lines.
    So obviously I have some questions...
    1. What am I looking at to have the AC system flushed and filled? Should I have a dealer do it, or an independent shop?
    2. While the front bumper is off, should I replace the coolant pumps, or are they "if not broke, don't fix it?".
    3. Would it be cheaper for a body shop to straighten that bent section, or have a new one (about $40) installed?
    4. . If anyone has spare parts they have for cheap, please PM me. Obviously things like the hood, fender, and front bumper would be too costly to ship.
    However I am going to need the center piece that runs in front of the radiator, the 4 radiator mounts and hardware (mine are very rusty), the top radiator bracket, both horns, front license plate bracket, the black grill (all 3 sections), the chrome grille part, driver's wiper arm, wiper cowl, and tons of bolts and clips.
    Lastly...since another used headlamp probably won't match well, is buying a new one off eBay ok?
    Thanks
    donbright and bisco like this.
    48,995
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Probably fair to call that a minor accident. But only because of how serious other accident's can be.
    But that still seems like a lot of damage done.
    I kind of file "minor accident" as being when you get out and look and you have a single dent or a couple of dents. That looks like quite a lot more.
    Also, I take it, this is almost exclusively a DIY non-insurance coverage repair?
    I'm not expert enough to offer specific advice.
    My only concern is making sure the vehicle you repair, is safe when you are done.
    I had to have a back bumper with FAR FAR less damage done repaired and I was told there is a compressible Styrofoam like material that absorbs impact, but once compressed it has to be replaced.
    Also, my limited experience with impacts and accidents is there is the visible damage, and then the possible unseen damage. Frame damage?
    Even if I was doing this recovery myself, I think I'd want a professional opinion as to the extent of the damage. Especially if the frame was possibly compromised.
    Might be totally cosmetic. But I'd want to be sure that was the case.
  4. Prius92
    Prius92 Member
    376
    95
    Iowa
    The frame is not compromised. That rail in the first pic is pushed in a tiny bit, that is it.
    The aluminum crash bar can be had new for about $50, if not I can find another one at the JY off a non-front-end-wrecked Prius.
    The Styrofoam is cheap too.
    Yes, stupid of me to not have collision coverage, but I'm broke.
    The hardest part of repair is getting all the plastic shrouds back in the right place. There are like 10 of them underneath and alongside the sides.
    That rail that holds the headlight and washer tank is the only thing that was bent. I will figure out next spring if it will be cheaper to get that part bent back, or a new one welded in. A new one is like $40 from Toyota, it will be painted black from the factory, but anything that isn't seen on the outside, I don't care what color it is.
    I tallied up everything I need. It will be about $800 to repair everything, and that's hopefully finding another good passenger fender, hood, and front bumper the same color at a junkyard.
  5. lech auto air conditionin
    830
    601
    260
    san francisco
    as for the a/c you already seal and plunged the end of the lines so you are good there. It will not be sitting exposed to the atmospheric for the next few weeks.
    Your new condenser will come with a new DRIER DESICCANT sock (bag). You will pay a few more $$$ for a Denso condenser but i Highly recommend it.
    If you can kindly ask the shop preforming the A/C recharge to at least leave it on the vacuum for at least a hour. Some plow right through it in 15 min save time make more money.
    if money to buy the ND-11 oil is not a option. Then a alliterative
    it will be better then what has been open to the moist air sitting in the shop for months or years. It is not that garbage sold in a plastic bottle at the auto parts store. Moisture actually go through plastic. The auto parts store POE and PAG has been sitting for years.
    40ml. oil added for the new condenser
    gusstament for oil loss from puncture and rapid loss of refrigerant in liquid state from condenser ( 20ml )
    total = 60ml.
    give the rest to the shop. it had been open and will be bad soon. The shops will use it any way.
    no need to flush you a/c system. you sealed it.
  6. bisco
    48,995
    thank you lech, you're the best!(y)
  7. Prius92
    Prius92 Member
    376
    95
    Iowa
    I am starting to source parts.
    There are two "side seals" that go on each end of the radiator.
    Are they necessary to put back on? Mine have broken tabs, and they are $45/each new.
    I've never seen them on other car bodies either.
    Here is a photo.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,101
    5,812
    Columbia, SC
    I would put them in, as they most likely are air flow control to make sure cool air is directed correctly to the radiator, and hot air is not recirculated when sitting idle.
    If you're not in a big rush, I could probably pull them off my 2007 parts car and send them to you. As far as I know, they should be undamaged. Were yours broken from the wreck or when removing them?
    Well, I just went and looked at the car since I had already removed the front bumper cover. It looks like getting to the back of those tabs to release them would require removal of everything between the engine and bumper. I really don't have time available for that much disassembly. If it were me? I would explore cleaning the surfaces really well and using a tube of good construction adhesive or silicon adhesive. And maybe some self tapping screws.
    #8 TMR-JWAP, Dec 16, 2019
  9. lech auto air conditionin
    830
    601
    260
    san francisco
    Yes definitely replace them if money is a little bit of tight issue and aesthetics is not that important a little JB Weld hot glue and Enginuity goes a long ways.
    It’s better to have two cracked ugly looking air dams replaced on both sides of your condenser than nothing at all.
  10. Prius92
    Prius92 Member
    376
    95
    Iowa
    I sent you a pm a few days ago.
  11. TMR-JWAP
    6,101
    5,812
    Columbia, SC
    Sry about that. Been up to my eyeballs lately. My parts car is Canadian, eh. No one in this world would want any metallic items from this car. It's middle name is Rusty. It's one reason I decided to make it a parts car instead of fixing and selling it. Front bumper cover, foglights and grill are long gone.
