Front wheel hub/bearing assembly
Discussion in 'Gen 3 Prius Main Forum' started by Sharnold, Nov 8, 2019.
  1. Sharnold
    Sharnold Active Member
    400
    126
    Alabama
    Does the gen 3 prius have the built in abs/speed sensor in the hub assembly?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Yes. It is removable. The bearing itself has the phase ring built in and the knuckle houses the serviceable wheel speed sensor.
    #2 BZzap!, Nov 8, 2019
    Robert Holt and Sharnold like this.
  3. Sharnold
    400
    126
    Alabama
    Ty sir
  4. ChapmanF
    18,507
    My recollection was the tone ring was part of the driveshaft, not of the bearing. I could be wrong.
  5. Mendel Leisk
    41,865
    Repair Manual info:
