Do some Serious "thinking" before you just replace a head gasket
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fierofly, Nov 12, 2019.
Tags:
  1. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    I recently purchased a 2012 Prius V that was burning coolant, engine ran sometimes and sometimes it came to a dead stall upon start up. Had coolant in oil and white smoke. I removed head and found about 1/4 of coolant and a spotless clean combustion chamber on #1 cylinder and a bad head gasket. Now here's the question, how many people would just do necessary maintenance to replace head gasket and be on their way? Luckily, I decided to look at rods and sure enough, #1 was bent. So keep this in mind, I think this is a 13to1 compression motor, not much room for error
  2. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Bent rod undoubtedly due to hydro-locking.
    Mendel Leisk and Fierofly like this.
  3. bisco
    52,264
    yep, its not always what you imagine it to be.
    Fierofly and Air_Boss like this.
  4. Mendel Leisk
    41,810
    Did you catch it by checking the piston faces relative to top-of-block, or did it take disassemble, direct inspection of the pistons?
    The smoking gun in all this, it's almost always cylinder number one. And the EGR gas enters the intake manifold from the other end.
    How many miles on it, btw?
    anonymous likes this.
  5. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    It had 220mi. I was planning on rebuilding anyway. Didn't notice the Piston depth, it probably would have ran for a few miles with the slight bend it has, lol. Egr doesn't seem clogged. I'll post as I rebuild and find anything else. I replaced a 2006 Prius engine about a year ago with a 85k pull out. It had a broke rod. I still drive it, runs great.
    SFO and Mendel Leisk like this.
  6. RichG
    RichG Junior Member
    Houston
    Yeah - I have been reading the head gasket posts as my wife's 2012 is showing symptoms. I have so far removed the valve cover, I'm waiting for the Torx socket set to remove the EGR stud(was supposed to be delivered yesterday). I have read many posts including danlatu (who also had a bent rod) and The Critic write up their experience. All the information on here has been invaluable. The first thing I'm going to check when the head comes off is make sure the pistons come all the way up, esp #1. I really don't want to take the motor out...
    Best of luck - please keep us posted!
    SFO likes this.
  7. lrisius
    lrisius Member
    121
    57
    Illinois
    2015 Prius v wagon
  8. Mendel Leisk
    41,810
    I'm not sure myself. I know:
    1. The EGR gasses enter on the cylinder #4 end of the intake manifold.
    2. The head gasket failures are usually between cylinder #1 and #2.
    I can also dig up a pic of my intake manifold, soaking in the laundry sink:
    While not that obvious, maybe cylinders #1 and #2 are burbling up more stuff? Not sure.
    It may depend on the year too: as far as I know, earlier 3rd gen intake dump the EGR gas into a single gallery tube, and it branches off to the four capillaries, one per port. Later version, I think, the initial gallery splits into two intermediate passageways, then they in turn split into the capillaries.
    It is a bit bewildering, but known items 1 and 2 above, are factors somehow. I think.
  9. lrisius
    lrisius Member
    121
    57
    Illinois
    2015 Prius v wagon
    Thanks, Mendel! That helps. Bottom line for me is to do the cleaning.
  10. Mendel Leisk
    41,810
    I used Oxi Clean solution on the intake manifold, but you maybe want to be cautious. You can clean the IM pretty well with just Brake Cleaner (CRC brand or whatever). Oxi is very good for the EGR cooler, but maybe getting obsessive for the intake. And the downside with the intake: there are some threaded (and pass-through) bolt inserts bonded into the plastic, and if the Oxi solution is not completely flushed out, they can subsequently react with the bolts/studs screwing into the inserts.
    I had my IM off a second time, recently, and noticed a white crusty build-up on a couple of bolts. I cleaned them well and applied a little anti-seize, think it's in check now.
    Here's the boiler plate info on EGR and intake manifold cleaning, and some Repair Manual info attachments (torque values etc):
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    #10 Mendel Leisk, Jan 18, 2020
    NutzAboutBolts likes this.
  11. Shenine
    Shenine Junior Member
    GA, USA
    So, can you tell if you have a bent rod based on symptoms. For example, if you have never experienced hydrolock with the headgasket issue, is there still risk of a bent rod?
  12. rjparker
    10,400
    6,515
    Yes it is possible. That is why I said if "your" head gasket job escalates to an engine replacement, get new rings at the same time. A rod can be slightly bent and still run. However it will run badly in a different way than a leaking head gasket and may be noticed after the head gasket job is complete. Or the initial bent rod is very slight with minor impact but gets worse. Sometimes causing a hole in the block.
    The key is your mechanic actually checking the engine for other damage after it is torn down. Too often they get tunnel vision and just change the gasket. We have seen several owners go through this three times in a row.
    This video shows some of the worst case head gasket scenarios:
    #12 rjparker, Dec 29, 2021
    Shenine likes this.
