Gen 3 2010 Prius Rough, loud idle, knocking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chrillermiller, Dec 14, 2019.
Tags:
  1. chrillermiller
    chrillermiller New Member
    My son has a 2010 Gen 3. Started horribly knocking, shaking a few weeks ago. 225,000 miles. Was showing Generic Missfire codes and missfire on cylinder 1, 3, 4. Check engine light on.
    Took to local shop. They recommended plugs, coils, EGR cooler and valve. $2600.
    We took the car home and have done the following:
    Cleaned EGR cooler.
    Cleaned EGR pipe.
    Replaced EGR valve.
    Replaced Plugs.
    Replaced Coils.
    Replaced PCV valve.
    New MAF sensor.
    Removed and cleaned intake manifold.
    Cleaned throttle body.
    No codes showing as of now.
    Check Engine light will flash when accelerating quickly.
    The engine runs smooth at idle, but hiccups occasionally - feels like it missfires at around 18-23 MPH and 40 - 43 MPH.
    What's next to explore? I'm ready to give up.
    Priuslover09 likes this.
    51,944
    welcome!
    hopefully not the start of a headgasket leak
    tankyuong likes this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Mileage is up there
    Lets say no to head gasket :/
    How about the injectors?
    Did u look over all the vacuum lines etc?
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Are you loosing coolant?
  5. Mendel Leisk
    41,463
    Try a leak-down test.
    Leaving it to 225K to clean the EGR, and with those symptoms, I'd suspect it is the head gasket. Not the end of the world. If the leak-down test confirms it, replacement is doable.
    Radiospank likes this.
  6. chrillermiller
  7. chrillermiller
    Forgot to mention that. I did replace injectors.
    Visually inspected lines, and tried to put pump smoke through, but could not see anything.
  8. chrillermiller
    Bought the car at 200,000 miles. Not sure if EGR had ever been serviced/cleaned before.
    No done a leak down test. That checks the pressure under the spark plug to check pressure in cylinder?
  9. chrillermiller
    We didn't really notice if it was low until yesterday. It was a little low, but no visible signs of recent leak. Have topped off and ran it for a little while yesterday trying to see if losing any coolant now.
  10. Mendel Leisk
    41,463
    It uses a special 2-gauge set, applies pressure t cylinders one at a time (via the spark plug hole), with the cylinder at TDC on the compression stroke. The behaviour of the gauges tells things, and just listening at various places, you can tell if there's leakage from the cylinder into some other circuit.
    Google "eric the car guy leak-down test" for a pretty good video, though he has trouble with his (new) gauge set.
  11. chrillermiller
    10-4. Will explore looking for testing equipment. In the mean-time...
    Next question:
    I had said earlier that no codes were present. My son drove for a few miles this morning. Check Engine light came on.
    PO304 - Cylinder 4 Misfire - Does any of the recorded data from when the code was triggered tell us anything useful? For example, 1006 RPM. There are other data points - using RPM as example.
    TheeWood likes this.
  12. CharlesPrius
    CharlesPrius Member
    154
    60
    Mine had similar issues, needed new head gasket. Mech said it's a common problem for 2010. Electric water pump tends to fail on this model and there's no code for that so you just burn coolant without knowing it and one day it blows. I had it fixed and has run well for the past 35k miles. Now it's doing similar thing but i think this time it's the EGR circuit/valve/throttle/maf needs cleaning b/c i'm not losing coolant this time.
  13. Neil_onea
    Neil_onea Junior Member
    San Francisco
    Have you tried replacing the engine air filter? That stopped my misfire
