Lost Keys - 2004 Prius (Reprogamming)
Discussion in 'Gen 2 Prius Main Forum' started by 437115, Nov 24, 2019.
  1. 437115
    437115 Junior Member
    Australia
    i-Tech
    So we’ve stupidly lost all our keys to our 2004 Prius, VIN number starting with JTDKB(Gen 2 - No smart access) I managed to buy some second hand key fobs. From what I can see in these forums my steps are:
    1) Buy Mini VCI cable and install Techstream
    2) Hook up computer to car and use techstream to generate 96 hex code which I use to get a reseed code?
    the end of the "don't lose your keys or else" myth | PriusChat
    3) Then reset ECU and erase current fob keys.
    My questions are:
    - How do I get the reseed code? Can someone on this forum help me with that?
    - How do I erase the second hand fob keys, will they be erased when I reprogram?
    - Could this process cause major damage to the computer unit in the car?
    - Not sure if my car is imported from JAP, will that make a difference?
    Any help is greatly appreciated.
    ydpplqbd likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. 437115
    Australia
    i-Tech
    Thanks very much, ill give that a go but currently:
    I've bought the cable and installed techsteam v13-00-022 but I get the unable to connect to VIM error.
    My steps were:
    1.Connect OB2 cable
    2. turn on laptop
    3. open techstream
    4. clicked connect to vehicle
    is this correct?
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
  5. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Make sure the vim is selected under techstream settings.
