Guide: Replacing Stock Horn with Hella Supertone for Prime
Discussion in 'Prime Accessories and Modifications' started by Mavi, Dec 13, 2019.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So I replaced the stock horns on the Prius prime with Hella supertones. I've also done dualtones before and they're close enough to me sound wise. Both are an improvement I just went with the supertones since I got a new set for $13.
    Step 1: Pop hood, remove the 6 clips with a flat head screwdriver or plastic trim remove. Then pull off the plastic engine cover.
    Step 2: disconnect the connectors from both left and right horns.
    Step 3: use 12mm socket to remove the lower bolt from the horn harness. Do on both, stock horns will now come out.
    Step 4. Make a ground strap. I used a spare copper electrical wire, but any copper wire include speaker wire will work . I crimped it using home depot electrical connectors for the rest.
    Step 5: Use a screw driver or sand paper to sand under the intake box screw. This is where ground wire will bolt to .
    Step 6 bolt in the two new horns using existing screws.
    Step 7: Either of the two spade connection can be a ground of positive doesn't matter which. Plug the ground strap to one. And to the other horn as well.
    Step 8: now plug in the original positive spade you pulled from the stock horns earlier to the other.
    Step 9: test the horns. If all is well put the engine cover and clips back and close up.
    Cellboy likes this.
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    vvillovv and Salamander_King like this.
  4. Goat herder
    Goat herder Junior Member
    GREAT set of photos, and a clean upgrade of the
    Meep sounding horn.
    A month ago It was early morning I was waiting for a railway train to cross a state Hwy. Several semi trucks were heading back to the rock quarry they were using their train horns to honk at the train. Taking advantage of the " It was not me defense of violation of city posted ordinance "
  5. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    Thank you for posting this. I installed some Hella Sharptone horns today and it was very easy compared to my 2014 Prius.
    Mavi likes this.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Does someone have the part number for the absurd plastic push-pins holding the radiator cowl in place? A couple of mine are broken and I want to have replacements in hand when I do the horns.
  7. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
  8. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I found "90467-06133-C0" in another thread here and ordered some off eBay, we'll see. There may be different part numbers for the same item depending on which model its used in.
  9. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    BTW, these Hella horns with the Toyota connector are an exact fit. They come in LH and RH configurations and if you orient them correctly the existing connectors line up perfectly. They ground through the bracket so there's no messing with a ground wire.
    FWIW, the 90467-06133-C0 push pins are too small for the cowl. Trying 90467-07217 next
  10. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Awesome! thanks!
  11. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Following up, the 90467-07217 push pins appear to be an exact replacement, or at least close enough.
    Mavi likes this.
  12. chickenhawk
    chickenhawk Member
    261
    95
    CA
    These are on sale for $20 on Amazon, got a pair for my car.:cool:
  13. chickenhawk
    chickenhawk Member
    261
    95
    CA
    I put these Hella horns in and it really wasn't that much louder than the stock horno_O What is the purpose of the relay ? I just plug the harness on one side and the other pin I hooked to ground. I then honked my Highlander horn that was alot louder then this. Wth? So I'm boxing these and sending them back.
    I might try these out. Otherwise I will just get the OEM Highlander horns.
    Here are part numbers for the Highlander horns:
    upload_2021-4-22_6-12-1.png 865100E040 and 865200E020
  14. chickenhawk
    chickenhawk Member
    261
    95
    CA
    For those wondering #4 on the pic is the one that makes the hybrid sound in the Hybrids :cautious::whistle:
    SPEAKER ASSEMBLY, VEHICLE APPROACHING
    Part Number: 8657048031
  15. chickenhawk
    chickenhawk Member
    261
    95
    CA
    Well I tried these Hella horns and didn't like the sound ..looks I might use the freeway blaster that I used on my Gen 3 or put in the Highlander horn.
  16. FredtheWhale
    FredtheWhale New Member
    New Jersey
    Hi. I’m trying to replace my horn on a 2021 prime. Can anyone tell me where to buy a pigtail connector to fit the one that the original horn used? I know that i can snip the wires and reconnect.
  17. chickenhawk
    chickenhawk Member
    261
    95
    CA
    What happened to the original connector?
  18. FredtheWhale
    New Jersey
    The male side is built into the plastic housing of the oem horn.
