2011 - Dead JBL e7022. Should I replace just the digitizer or the lcd?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Obamanomicon, Dec 28, 2019.
  1. Obamanomicon
    Obamanomicon New Member
    A scary castle.
    So I really miss my touchscreen. My mom cleaned it a while ago and then the digitizer was dead basically. I've tried cleaning it and clean the crevices but nothing seems to help it. Think the digitizer is just toast. The screen itself is fine.
    So the specific MFD I have is a JBL e7022. I can get just the digitizer here. However I haven't seen clear directions on how to do that.
    However I'm wondering would I be better off just replacing the whole screen (screen + digitizer) since they are already assembled and about the same price? Also would this screen fit?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
  3. ChapmanF
    18,023
    Replace what?
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Replace the part
  5. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Who's on first? ;)
  6. Mendel Leisk
    41,259
    How'd she clean it? I'm thinking sprayed it, and the spray seeped into the electronics at the bottom??
    Was there supposed to be a link? You'll need a few more posts (4 or 5?) to be able to post links. You could just type out a good search string too, in the interim.
  7. Obamanomicon
    A scary castle.
    Not really sure. I think she wiped it with a wet wipe of some kind. It was a while ago.
    I'm looking at just the digitizer since the screeen seems to work just fine. Go to eBay and search "2010-11 Toyota Prius JBL E7022 Navigation Touchscreen Digitizer Stopped Working?" and you should see what I'm looking at.
    I've seen some tutorials on digitizer replacement but not for my exact model. So not sure if I can do it.
  8. ChapmanF
    18,023
    Isn't the whole title of the thread about which part to replace?
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I know. Just pouring gas onto the flame :ROFLMAO:
    RMB likes this.
