Red Triangle!! 160K Error codes C1241, C1256, C1310 Please HELP!!
Discussion in 'Gen 2 Prius Main Forum' started by Gincor4, Aug 5, 2017.
  1. Gincor4
    Gincor4 New Member
    Phoenix
    I'm getting the triangle with the VSC light coming on while driving. The car still runs fine but if I shut it off, then it won't go into ready mode. It'll stay in "accessory" (or whatever that in between mode is called...limbo?).
    I have a wifi OBD that I plug in and get a bunch of incomplete codes on the DashCmd app (which seems kinda useless), but it does allow me to clear the codes. After I clear them, the car starts up and runs fine, sometimes for days, then the triangle comes back on.
    I took it to Advanced Auto Parts to get scanned while the triangle was up.
    The codes they read were:
    C1241 - Low Battery Positive Voltage
    C1256 - ABS Inlet Valve Coil RR Circuit Short To Battery
    C1310 - Malfunction in HV System
    On top of all that, the brake actuator is making that "rattling" noise very often even after the car is off.
    Also, I've tested the 12V battery and it's fine.
    Thoughts?... Bad brake actuator? Hybrid Battery? Bad ECU?
    49,469
    welcome!
    what were the 12v results?
    Gincor4 likes this.
  3. Gincor4
    Gincor4 New Member
    Phoenix
    Don't remember exactly, but it was on the higher end of 13V.
    It's an optima I replaced about 4 years ago.
  4. Gincor4
    Gincor4 New Member
    Phoenix
    ...of course that was at the auto parts store that it was tested.
    I just tested it and it was about 12.14, then 13.4 running, then 12.8 after I turned it off.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    12.14 is dead. 13.4 is at least 0.2v shy of normal charging voltages of 13.6-14.2v.
  6. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    999
    The one start and done condition is caused by a high voltage leak. The codes for that are a P3009 or a P0AA6. The code reader at Advanced Auto is not reading all the codes.
    Contact Steve at Phoenix Hybrid Batteries. He can read the codes and fix the leaks. The likely sources for the leak are the HV battery, transmission, or AC compressor.
    Brad
    m.wynn, Raytheeagle and Gincor4 like this.
  7. Gincor4
    Gincor4 New Member
    Phoenix
    Thanks strawbrad! I actually talked to Steve yesterday and he pretty much said the same thing.
    I'm meeting up with him tomorrow so he can test it.
    Raytheeagle likes this.
  8. strawbrad
    953
    999
    Hopefully the codes will be there when you meet up with Steve. No one can read codes that are not there! The trick will be to get the codes to light upon the way to being tested.
    Brad
  9. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
  10. 05PreeUs
    1,097
    563
    MSP
    Document Link: https://attachments.priuschat.com/attachment-files/2016/05/106672_Toyota_ZG1.pdf
    Text (emphasis added):
    This Warranty Enhancement Program provides enhanced coverage to the vehicle's
    "New Vehicle Limited Warranty" as it applies to the Brake Actuator Assembly. The specific
    condition covered by this program are repairs related t0 an internal malfunction of the Brake
    Actuator Assembly. lf the condition is verified, the vehicle will be repaired with a new Brake
    Actuator Assembly at no charge under the terms of this Warranty Enhancement Program.
    The Primary Coverage offers warranty enhancement until December 31,2017
    regardless of mileage. After the Primary Coverage ends, the Secondary Coverage is applicable for
    10 years from the date of first use, or 150,000 miles, whichever occurs first.
    Please note that this coverage is for warranty work performed at an authorized Toyota
    dealer only.
  11. Elson
    Elson New Member
    Oakland
    Does
    "The Primary Coverage offers warranty enhancement until December 31,2017,
    regardless of mileage. After the Primary Coverage ends, the Secondary Coverage is applicable for 10 years from the date of first use, or 150,000 miles, whichever occurs first"
    mean that secondary coverage is also free replacement ten years *from 2017,* or 150,000 miles, wof? ...cause that's literally what it states...
  12. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    It doesn't say that at all, literally or figuratively. Secondary coverage is from 10 years of car's first use, or 150,000 miles, whichever occurs first.
