Battery Control ECU needs replacing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ProspectivePriusPeruser, Jan 19, 2020.
  1. ProspectivePriusPeruser
    ProspectivePriusPeruser Junior Member
    Australia
    I was going to have Toyota do this but the time it will take to have the part shipped in is ridiculous (6 weeks). How hard is it to DIY this? I have access to a 2nd gen parts car, could I just rip the ECU from there and chuck it in mine, or is it not that easy? Cheers
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    See my posting from earlier this month about battery ECU replacement. A battery ECU salvaged from a newer (but still second-generation, 2004–2009) car should work in an older one, but I don’t know about the reverse.
  3. ProspectivePriusPeruser
    Australia
    Ah heck, the one I can pull parts from is a 2007 or 8 and mine is a 2009. Thanks anyway, this will be a looooong 6 weeks.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    It might be worth checking the part number: 89890-47092 is the latest version, used in new production from April 2007, and it should work in all second-generation Prius cars.
  5. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Were you successfully able to scan the OBD2 port for DTCs?
    Which stored code(s) came back, and how do you know it needs another battery control ECU?
    Raytheeagle likes this.
