Oil Catch Can Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Roberto III, Jan 27, 2020.
  1. Roberto III
    Roberto III New Member
    North Carolina
    Have a 2012 - installed an Oil Catch Can - now have two error codes (C1241) and (P0441). There are no leaks, everything is routed correctly, and NutzAboutBolts makes it look a way too easy. Any help is appreciated. Thanks!
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    battery voltage low & evap problem /
    got nothing to do with the oil catch can /
    Cosmo Tigato likes this.
  3. Mendel Leisk
    41,333
    Know you say you've reconnected everything correctly, but: did you remove the intake manifold for access? There's a gas tank vapours routed back to the intake manifold: goes through an electrically activated valve bolted to a bracket on the right side of the manifold (as you stand at the front, looking into engine bay). Check that it's connector is on, and the hoses connecting to it, and the hose running from the valve to the intake manifold (at spigot just below throttle body) are connected/secure.
    Not sure about the other code, but considering you just did something and now you've got a code, something not reconnected.
