Change hybrid battery pack
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by fadisabo12, Oct 17, 2019.
  1. fadisabo12
    fadisabo12 New Member
    texas
    My vehicle run good, some times all lights glow and request to change hybrid battery pack, I check the battery its charge more than 7.6 volt each cell, I clean the junctions and reinstalled, aging its shows the same, I have felling the issue not in battery, kindly advise. thanks.
  2. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    Next step is to test the voltage of each module under a load... A 55w halogen headlight bulb running that 7.6v down for 2 minutes will show a decrease in voltage at the exact end of between .2 and .4 volts. One of those modules in your pack is likely bad and you will find it because it will lose .5 to 1 volts after two minutes. There's lots more to it than just that, but that's the next test that needs to be done.
  3. fadisabo12
    texas
    Thank you for your massage, I check the cells its 8 to 7.9V after two minuets test, every time when I reset the vehicle its working back properly, its happened some times when the battery is full.
    please advise.
  4. PriusCamper
    13,021
    5,291
    Sounds like you checked the voltage for two minutes, but you didn't check how much the voltage dropped when the battery module was lighting up the light bulb. A load test is so you can watch how the battery drains down for two minutes when connected to a lightbulb. Then you record how much the voltage dropped.
    The bad battery module that will need to be replaced will drain down much faster than the other battery modules...
  5. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    I’m curious. What is the mileage?
  6. fadisabo12
    texas
    Around 150k mile,
    I test all cells after two minutes, I found one cell 7.49v I change it, but now every two minutes need to resets the codes and the fan going on high speed at that time
  7. PriusCamper
    13,021
    5,291
    As I said before, something is wrong with how you're doing your diagnostics... Can you please respond to my post above so we can be more helpful?
  8. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    Make sure to put the battery temperature sensors more at the center of the battery pack, that's where it gets the hottest so the fan will keep them at a more cold temperature. Also please make sure the fan and fan ducts are clean, no corrosion in contacts, and again check the temperature sensors and locate them more at the center of the battery.
  9. fadisabo12
    texas
    I check each cell and use the load for 2 minutes No cell shows any drops
    When The engine light on still the vehicle continuous charging I change the computer and temperature sensors still I have the same problems I bought two cells, use one of them after that when it’s lighting the engine light the fan going in very high speeds Before engine lights need to be on 60 minutes no every five minutes
  10. PriusCamper
    13,021
    5,291
    Make sure to use a 12v 50w or 55w incandescent or halogen bulb... You take the voltage reading at 2 minutes before you disconnect the light bub... If you're doing it correctly you will measure a drop between 0.2v and 0.5v... The bad module will drop even more than that.
