Brakes making clunking noise?? 2010 Prius
Discussion in 'Gen 3 Prius Main Forum' started by Lynde Lu, Feb 12, 2020.
  1. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    Hi all!
    Just got back from driving about 500 miles in about 12 hours enduring stormy weather and lots of water on the highways now my brakes are making a very loud nonstop clunking noise while I'm at a complete stop. Anyone else have this same issue?
    Recent maintenance:
    July 2019 rotors trimmed
    August 2019 had the master brake system checked, no issues found
    September 2019 rotors re-trimmed and new brake pads
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Why did you have the brakes redone after only 2 months? That sounds like there was a problem well before now.
  3. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    That's what I've been trying to figure out but everyone I've taken it to says there's no problem the rotors just need to be retrimmed.
  4. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    UPDATE: Local mechanic believes it's the brake booster pump going out
  5. Higgins909
    Higgins909 Member
    277
    67
    I've noticed my brakes make clunking noises when wet and was sitting for 8+ hours or so... maybe when backing out. But that's only for the first few minutes of my drive. I don't know how it could be making a constant sound when stopped. It just all wheels or just one? Maybe there is something wrong with the ABS sensor. Any lights on the dash? I've gotten ABS to go off when leaving work and the pump is pretty quiet, but the brakes themselves make strange noise. (Short and steep driveway, wet out, ...forgot what I was going to say) I kinda wonder it it's even ABS and just the pads being wet and not grabbing correctly.
    Maybe you could make a video?
  6. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    It's the oddest thing, not consistent only happens occasionally but this last drive it wouldn't stop since I was in rush hour traffic through neighborhoods. Only makes the sound while my foot is on the brake at a complete stop regardless if I barely have my foot on the brake pedal or if I'm pressing down hard. No ABS light or lights on the dash; I got a video of it but I'm not sure how to upload it on this form :(
  7. Lynde Lu
    Lynde Lu New Member
    Austin, TX
  8. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    Anyone experience this braking noise while at a complete stop?
    https://photos.app.goo.gl/oUp9aimvWHgtyzq59
    Just got back from driving about 500 miles in about 12 hours enduring stormy weather and lots of water on the highways now my brakes are making a very loud nonstop clunking(?)/barking noise while I'm at a complete stop. No ABS light or dash lights, anyone else have this same issue?
    Recent maintenance:
    September 2019 rotors re-trimmed and new brake pads since the dealership stating the rotor trimming was botched
    February 2020 mechanic believes it's the brake booster pump (cost estimate 1200.00)
  9. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    One thing about the brake booster, it does not know or care how fast the wheels are turning. But your sound seems perfectly timed for each revolution of the wheels as you come to a complete stop. I am sorry to say it, but that points to the rotors not being true. I would say it's time for a competent shop to put new rotors on the car. The job also calls for lubricating the calipers with a dollop of the proper grease.
    Johnny Cakes likes this.
  10. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Something else seems to be happening.
    Please verify if you are at a complete stop, not moving at all during that video?
    The booster is constantly cycling (low moaning bark) and the other higher pitch noise sounds like ABS/traction control.
  11. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    I'm not moving at all, at a complete stop at a stop light. It doesn't happen all the time just sporadically but this past time was nonstop and kind of freaked me out.
  12. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    After two rotor trims within a month, I wonder why they didn't just replace the rotors. The car is ten years old, I wonder if the rotors have hit the end of their lifespan?
  13. Mendel Leisk
    40,540
    The rotors are probably fine, unless they've machined them down below min level. You can check for yourself with dial gauge (with magnetic base) and micrometer, specs in attached. And if you're not noticing pulsing when using the brakes , again, shouldn't be a rotor problem. If this noise is with the car stopped, there's no reason to be suspecting the rotors.
    I doubt it's the rotors... :ROFLMAO:
  14. ASRDogman
    ASRDogman Senior Member
    7,186
    3,762
    Getting confused..... The brakes only make noise when the car is STOPPED???
    Are you certain it is the brakes? And not something else?
  15. BZzap!
    BZzap! Senior Member
    1,607
    878
    Maybe it’s the ICE shutting down. Sometimes mind lurches a bit when it shuts down at a stop.
    ASRDogman likes this.
  16. ChapmanF
    17,256
    Any chance of just attaching an .mp3 file or such on PriusChat? The photos...goo.gl link seems to have more in mind for me than just playing some sounds.
  17. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    I hear the brake pump running way too much and something else -- maybe ABS? -- going crazy. Something is seriously amiss.
    How's the fluid level?
  18. Pluggo
    608
    533
    The car is making that noise while stopped? That changes everything. Forget about the rotors for now.
  19. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    According to the mechanic fluid levels are good and the car is in good shape. I drove during rush hour traffic yesterday to try to recreate the noise but it didn't make any alarming sounds. I wonder if the long road trip might have triggered it?
  20. Lynde Lu
    Lynde Lu New Member
    Austin, TX
    Exactly, it's beyond wacky.
