Dashboard symbols frustrating
Discussion in 'Gen 3 Prius Accessories and Modifications' started by scotttyb68, Feb 16, 2020.
  1. scotttyb68
    scotttyb68 Junior Member
    25
    michigan
    One thing that bothered me about my 2 gen and 3 gen is the total lack of information that the dashboard gives you. The other day the tire symbol lit. Don't know what tire is low, so have to check them all in a blizzard. I never know things like oil pressure temp voltage etc. Is there any aftermarket obd2 system that can tell you what is going on with your car?
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    "Hybrid Assistant" app for Android works great for the usual behind-the-scenes data. It has a companion app called "Tire Assistant", which does exactly what you want. You're catch is the ODB-II reader is $50.
    scotttyb68 likes this.
  3. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I feel your pain
    MI CC 9e ?
  4. 12voltman
    12voltman Member
    124
    93
    As high tech as our Prius' are ...........they cant even tell us when the windshield wiper fluid is low !!!! Nope , lets it run right out before we have a clue there is NONE left !
    That frustrates me to no end ! lol
  5. john1701a
    12,833
    5,310
    58
    It does tell you when the FOB battery is getting low.
  6. bisco
    52,390
    The information is there, not sure why Toyota is reluctant to disclose it
  7. ASRDogman
    ASRDogman Senior Member
    7,819
    3,983
    You're supposed to be doing weekly checks..... :)
  8. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I tried this Tire Assistant, but provided no data for my European Prius - and it has pressure sensors in the wheels.
  9. Prodigyplace
    12,678
    11,830
    Central Virginia
    Something like this work?
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    App didn’t work for me either. But it wanted permission to access my photos, videos, location and etc. Good thing it was on a phone that used for app testing and experimentation only so I granted it access to a blank phone.
  11. scotttyb68
    25
    michigan
    Thanks everyone. At least I'm not the only one bothered by how tight lipped the Prius can be.
