Liftgate Garnish bolts and nuts
Discussion in 'Gen 2 Prius Main Forum' started by Bluesman78, Feb 29, 2020.
  1. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    where do I get the liftgate garnish bolts and nuts?
    I do have the bolts that came with the replacement part but I wanted to upgrade them. The nuts, on the other hand do not screw on well to the either the old bolt (which are very rusted and junky) or the new ones.
    Would the dealer assist or would going to autozone suffice or home depot.
    I'd rather spend a little more for better quality bolts (I got an aftermarket one and this is my third time breaking it and each time it gets more painful to replace it).
  2. PriusCamper
    PriusCamper Senior Member
    12,840
    5,204
    Pacific Northwest, USA
    If you've broken it 3 times there's probably something wrong with how you're using it or how you fixed it... I've not ever replaced one so I don't know the details, but if you go to a local hardware store #8 steel is going to be the highest quality fasteners.
  3. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    No doubt it could be fixed differently or used differently, I could give you a variety of explanations but i'm fine with doing my best. Thanks for the response.
  4. PriusCamper
    12,840
    5,204
    I had to do an internet search on "garnish" to understand what part of the car you were referring to... Perhaps others with more experience working on that part of the car would chime in if they knew what "garnish" was... According to what Google told me it's the pic below, is that correct?
  5. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    That's right, it's a major Prius design flaw and also exacerbated by user error. In my case many people use it and don't use it right. The garnish above has been redesigned to help prevent errrors.
    PriusCamper likes this.
  6. PriusCamper
    12,840
    5,204
    I have seen a couple of those falling off on Prius around town, but never noticed and problems with all the Prius I've worked on...
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    I'm a bit at a loss about the bolts. I've seen plenty of these pieces after failure, and it's never been a fastener failure. Not sure why an upgrade is needed. It's always the plastic that breaks.
    They're not exactly a standard bolt/fastener. Square headed so they can't spin in the housing while the nut is loosened or tightened.
    Aegean likes this.
  8. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    The old nuts did not screw onto the new bolts that come with the piece. So not sure what to do. Also I had a heck of a time trying to remove the old nuts, not sure what went on there. They are only 18 months old. I know they get corroded. It was also cold yesterday (around 32D F), not sure if that had something to do with that.
  9. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Have you checked or replaced the liftgate/hatch struts lately?
  10. Elektroingenieur
    2,515
    3,284
    Three Touring
    A Toyota dealer should be able to sell you the correct nuts (90179-05102) and rubber washers (90562-04007); you need four of each. The bolts are not sold separately from the garnish sub-assembly. See catalog Figure 75-04, Rear Moulding.
    Todd Bonzalez and Mendel Leisk like this.
  11. TMR-JWAP
    6,404
    6,092
    Columbia, SC
    The thread size of those studs (OEM anyway) is M5 with 0.8mm pitch. The same as the threads on the HV battery modules. The nuts are oversized hex flange nuts with 10mm flat to flat. I have a box of 500 and would be happy to send you some if you need them.
    I have yet to see any corrosion on any garnish fasteners I've been across. If you're getting something significant, there may be some water leakage issues that need investigating.
  12. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    No, the trunk stays open just fine so not sure why they would need to be replaced?
  13. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    Sent you a direct message. Thx.
    Raytheeagle likes this.
  14. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    Hey, are you guys discussing the 4 bolts that connect the liftgate the the car body metal frame?
    I bought 5-mm x 0.8 Stainless Steel Hex Nut from a franchise hardware store and they look really small. And the one bolt I got (I misplaced the other one or two) is a lot bigger.
  15. TMR-JWAP
    6,404
    6,092
    Columbia, SC
    Yes, we're talking about the same fastener. Although they are the same thread size and pitch, the garnish uses an oversized 10mm hex, where a typical nut for that thread uses an 8mm hex head. Do you need some of the larger size nuts?
  16. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    Yes.
    Also, you were right about the thread and pitch.
    But the nuts I got from the hardware store were super small. I couldn't tell the size from the website. But they were no bigger than M&M candies.
    *Edit: I'm anxious to put back my handle. I took off interior panel.
    Right now, I'm looking at serrated flange nuts from your friendly neighborhood Amazon.
    #16 Toyotally04, Jan 27, 2024
  17. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    Does this spec look right?
  18. Toyotally04
    Toyotally04 Member
    130
    17
    SoCal.
    The ones I purchased and later returned were smaller than the ones I had taken off from the car. I was expecting the nut height and nut width to be much bigger.
  19. TMR-JWAP
    6,404
    6,092
    Columbia, SC
    The one shown in post 17 is the small one. The width across the flats is 8mm, which is also the size socket that will fit it. You need 10mm across the flats. If you PM me an address, I'll send you some.
    Toyotally04 likes this.
  20. ctopherine
    ctopherine New Member
    Madison, WI
    I was wondering if I have the same issue. The bolts were corroded on mine I think from when the plastic part broke. I drove with it broken for a while. I had to have a mechanic help me get the bolt off, and they drilled it out. I still have one, but I need the nut. I also need two others I think. I couldn't figure out how to buy them from the assembly diagram. I read elsewhere that the only way to get them is to buy the full assembly?
    Here's a picture. I need that and the bolt.
    Let me know if this should be a different conversation. This is my first time posting here! Thanks!
