What is everyone using for spark plugs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tak1313, Mar 2, 2020.
  1. tak1313
    tak1313 Member
    MA
    I tried searching, and I don't know if it's just me, but it appears the (now) recommended Denso SC16HR11 is discontinued? Everyone that I would trust (ie. NOT Ebay) says either discontinued or out-of-stock. That includes big guys like Rock, SparkPlugs, Summit, etc. Even when trying to link through the "Buy Online" of Denso's website, just about everybody showing in the links say "not available." Even the ones that you CAN link up to (SparkPlugs), show not available when you actually go to the site.
    Is it REALLY discontinued, or is it a matter of supply shortage?
  2. Mendel Leisk
    41,873
    Have you tried any local automotive specialty stores? Preferably someone you've used before, they know their stuff.
  3. tak1313
    tak1313 Member
    MA
    I have not physically checked, but the AutoZone link on Denso's site says "not available." Going directly to AutoZone's website and entering 'sc16hr11' initially shows 'spark plugs' as one of two options. Clicking on that link bring up 'no results in this parts category.
    Advance Auto (the last place I bought the sc20s) no longer shows either as available. Rock shows 'out of stock' and you can enter your email to be notified when it's back in stock. Sparkplugs says 'this item has been discontinued.' Summit shows 'not available.'
    The closest I can find is a some sites bringing up sK16hr11 when searching, but I can't find any info if it's some kind of supersession of the sC16hr11.
  4. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    What year is your car, and isn't it the SC20HR11 (aka 3444) that's specified?
    That plug is showing as available from O'Reilly and Amazon, along with online Toyota dealers. McGeorge Toyota is often a good source, and for the plug, they are showing at $8.94 each--throw in some filters to make the shipping worth it.
  5. bisco
    52,360
    Spark plugs
  6. Mendel Leisk
    41,873
    That's what Owner's Manual shows, but apparently Toyota later decided a slightly hotter plug was warranted, it was developed, and assigned Denso part number SC16HR11,
    pjksr02 likes this.
  7. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    SK won't fit yer car... without looking it up, I believe that's the Gen2 spark plug.
    Everyone except Toyota seems to be out of Densos that fit Gen3.
    If I needed plugs right now I would order from McGeorge
    pjksr02 likes this.
  8. tak1313
    tak1313 Member
    MA
    priumium and Mendel Leisk like this.
  9. Bbonez
    Bbonez Member
    40
    44
  10. Mendel Leisk
    41,873
    Assuming they're the correct Denso, I wish they'd show the denso number as well.
    Maybe googling the toyota part number you can find an image with the denso part info.
    #10 Mendel Leisk, Mar 4, 2020
  11. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Assuming they're the correct Denso, I wish they'd show the denso number as well."
    A bit of further searching indicates that those are probably the 20's rather than the 16's, assuming they're legit.
  12. Bbonez
    Bbonez Member
    40
    44
    The ones I got were the 16s.
    pjksr02, Mendel Leisk and Nor'easter like this.
  13. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Never realized you can do that on the internet.
  14. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    I finally get to return a favor!
    Here is the entry point to the Denso cross reference, also note tabs that take you to general spark plug info. This is a terrific, one stop shop for all things related to spark plugs. Denso cross references Toyota (and other auto manufacturer) part numbers.
    pjksr02 and Mendel Leisk like this.
  15. Mendel Leisk
    41,873
    Some notes I made from the above:
    spark plug: denso SC20HR11 (toyota p/n: 90919-01253)<superceded
    (requires 14 mm or 9/16" socket)
    Note: the denso Denso SC20HR11 has been supersceded with Denso SC16HR11 now, slightly hotter
    Toyota part no for SC16HR11: 90919-01275
    Denso part no for SC16HR11: 267700-8300
    Thread: 12 dia x 26.5
    Denso torque recommendation for above thread dia:
    15-20N·m (11-15 ft/lb)| About 1/3 turn (new)| About 1/12 turn (used)
    Denso cautions to not use lube on threads
    1/3 turn: 120 degrees (90+30)
    1/12 turn: 30 degrees
    #15 Mendel Leisk, Mar 4, 2020
    Burnt_reynolds and pjksr02 like this.
  16. pjksr02
    534
    227
    Connecticut
    Now that we cleared that up, what about the gap on these "do not adjust the gap" plugs?
  17. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Do not adjust them.
  18. Mendel Leisk
    41,873
    They should be preset to that, sort of trust but verify. If they're off, I'd consider returning them?
    2014 Member
    30
    31
    MA
    Just bought spark plugs: denso SC16HR11 (toyota p/n: 90919-01275) at a dealer. List $13.20 each, out the door for $11.88 each.
    Burnt_reynolds likes this.
