HELP! whole dash just lit up on drive home. Scanned it with scanner NO CODES popped up.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Banksy, Mar 6, 2020.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    250k
    No issues until now
    Triangle is on along with VSC, check engine and among others.
    Battery is reading fully charged. What's going on?
    52,286
    tech stream
    SFO likes this.
  3. Banksy
    415
    132
    Just scanned it with my other tool at home
    Saying to replace the battery pack.
  4. Desert Flier
    Desert Flier Member
    68
    Phoenix
    This is an excellent short video of how easy replacing the battery pack is.
    MNR0725 likes this.
  5. Banksy
    415
    132
    Prius:
    2008
    Milage: 250k
    I was driving home from work tonight when all is the sudden it was Christmas and my dash was the tree.
    VSC, engine, triangle, some other light that looks like a circle with ! In the middle. Along with on the nav a picture of a car with a ! In the middle.
    Had a cheap scan tool in the car. Zero codes pop up. Took it home where I have my Autel.
    No engine codes, one module said to replace the HV battery.
    Is there anything else going on here?
  6. Banksy
    415
    132
    Actually watched that a few weeks ago
    Replacing it isn't the issue for me
    Previous owner had it replaced.
    Has a warranty apparently.
    I think they only swapped a few cells rather than the while thing
  7. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Care to share the DTCs?
    From which company, and is it transferable?
    Raytheeagle likes this.
  8. Banksy
    415
    132
    Replaced here
    Planning on calling them tomorrow
    Give me a minute and I'll share the code
  9. Banksy
    415
    132
    Only code was in that third module.
    Which I listed in the pic
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Could be the HV battery
    Can you see live data for each of the 14 Battery blocks?
    If not get an elm 327 adapter and Dr Prius app. ( Or torque Pro app)
    Look for any blocks that are much higher or lower than the rest.
  11. Banksy
    415
    132
    I think they only replaced a few cells.
    Total for the job was 500.00
    I don't think that'd cover the cost of the 28 cells themselves. Let alone labor
  12. Banksy
    415
    132
    I know this scan tool can do live data.
    Just don't know how.
    That'll be for tomorrow
    If this helps lmk.
    Only codes where found in the third module.
  13. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Didn't see a physical address, please report back with their contact # if they fail to honor that warranty.
    Quite possible that scanner isn't totally compatible with your vehicle, there could be some missing DTCs.
    Hopefully it will be enough to cover their fuel to fix it over the next six (6) months o_O
  14. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    That's a generic code.
    I'm looking for something like p3011 or something near that range.
    With the $6 Torque Pro app and a Bluetooth OBDII adaptor you can see live data like this.
    Easy to quickly see the outlier.
    Notice block 8 is vastly different than all the rest. Block 8 at 15.2v, rest are above 16v. This is bad news. Failed module.
  15. Banksy
    415
    132
    I actually have torque pro
    My Bluetooth scanner is in my neighbors car. Will definitely pick that up tomorrow
  16. Banksy
    415
    132
    Is it the battery or something else?
  17. Banksy
    415
    132
    Here is said contact info.
    Previous owner had them do this.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Ever replace the inverter coolant pump:whistle:?
    But I'd get the codes before you take the parts shotgun approach(y).
  19. Banksy
    415
    132
    No idea
    I don't know the service history of this car
    Just got it on the road like a week ago
  20. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Did the car go into limp mode when the lights came on?
    After the car sat for a bit, did it run normally?
    Is there movement in the reservoir for the inverter coolant?
    Are all fuses in tact, or are any blown?
    These are classic signs of the failed inverter pump.
    SFO likes this.
