Broken charger cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Malonista, Mar 21, 2020.
  1. Malonista
    Malonista New Member
    sweden
    Hello
    My 2012 plug-in Prius charger cable seems to have gone slightly bad from regular use. It is a first generation G9060-47190. The short cable with the wall plug has a bad connection to the charger, it connects when I apply pressure on the cable towards the transformer.
    New chargers are really pricey about $600. And it seems like a simple thing to repair, just replace the cable with the plug.
    However I cant crack the charger case open. There are screws on the bottom, they come out fine. But the cable socket has some kind of plastic rivet on it. See picture.
    Does anyone here know how to crack the charger open to replace the bad cable?
    Sincerely
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    I checked my charger and must agree that it looks like a rivet, not an Allen screw, not a compression pin. For my money, I'd lightly drill the rivet until the raised rim is gone, then I would see if I could pry the plastic over the remaining stump. You can always just buy a compatible charger for about $150.
    Malonista likes this.
  3. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hello, if you need a charging cable, I have a spare cable from a Nissan Leaf. Works fine. PM me if interested.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    There's the quick and easy solution, @Malonista. (y)(y)
    And if that doesn't work out for you for some reason, they are plentiful on Ebay.
  5. Malonista
    sweden
    If the Toyota workshop won't repair it then I will try to drill the rivet.
    Pluggo likes this.
  6. EVDoctor4Earth
    EVDoctor4Earth New Member
    Carlsbad, California
    Hi - Yes the Prius Charger is tough to open, Drill out the rivet ~ 1/4" deep, Unscrew the clamp, Then there is a small clip holding the next clamp on, Pry out the clip with a sharp point awl and you find a small spring and 2nd clip, remove them and unscrew the 2nd clamp. CAUTION - Generally those cords go bad because the wall outlet is weak and this heats up the plug to the point of melting. Replace the outlet with a Commercial Grade outlet. You may be able to buy a used replacement AC power cord. Check our website EVDoctor4Earth for additional instructions.
    vvillovv likes this.
  7. BiomedO1
    4,125
    2,166
    SacTown, Ca
    IMHO; you should replace it with a "hospital grade" outlet and plug, they have a green dot on them. Hospital grade equipment has a minimum measurable standard they must follow 'NFPA-99 standard'. Any unscrupulous manufacturer or knock-off can label their products commercial grade.
  8. bisco
    52,382
    hopefully, it's already fixed
    jerrymildred likes this.
  9. BiomedO1
    4,125
    2,166
    SacTown, Ca
    LoL; nice catch - only skimmed the previous post:D:ROFLMAO:
  10. Betul
    Betul New Member
    Annapolos
    2018 Prius Prime
    which chargers at that price? compatible with Prius?
  11. BiomedO1
    4,125
    2,166
    SacTown, Ca
