05 Prius AC only cold at highway speeds...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DougDA, Mar 26, 2020.
  1. DougDA
    DougDA Junior Member
    Alabama
    My daughter's prius has started blowing cold air only if the mph is 50-60mph?
    I've replaced the compressor and recharged it at the beginning of last summer and it has worked well up to this point.
    Ideas what to check first?
    I had this happen on a newer VW and it was related to the throttle body not being indexed - apparently the ecu couldn't determine the location of the throttle so it would not allow the compressor to come on below 2400rpms.
    52,391
    i wonder if a weak hybrid battery could cause that
  3. DougDA
    Alabama
    definitely worth checking the voltage...
    from what i understand, thats a decent assumption to anything odd on a prius.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Usually means the condensor fan(s) aren't working or the system is in very poor operating condition.
    GOOD LUCK!
  5. DougDA
    Alabama
    what would constitute - poor operating condition?
    low freon?
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    My guess would be the condenser/radiator is clogged with junk and not allowing air to pass through. Use high-pressure air to blow out the crud. ALSO, how about the cabin air filter behind the glove box?
  7. ChapmanF
    18,547
    There's also a pretty classic explanation where the electric condenser fans aren't working. At highway speeds, there's natural airflow through the condenser. At lower speeds, if the fans aren't running, there isn't.
    Another variation on that is where electrical connections got jacked around somehow and the fans are trying to blow forward.
