Installing rear wiper?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Sixstringer, Mar 30, 2020.
Tags:
  1. Sixstringer
    Sixstringer Junior Member
    2020 Prius
    L Eco
    Just bought a 2020 Prius L Eco. Assumed it would have a rear wiper, as my previous Prii did. Muh bad.
    Is it possible to install a rear wiper on it aftermarket?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Nothing is impossible - maybe. OK, OK - some things are.
    You'd have to replace the back glass, get the wiper mechanism, and work out whether the wiring is in place. Then have to replace the steering wheel stalk, possibly it may not work anyway because the computer doesn't recognise it.
    So - maybe it isn't possible, sorry.
  3. Sixstringer
    2020 Prius
    L Eco
    Gaah. ok I'll suck it up and buy some Aquapel. Thanks for the response.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    That's funny. The go-to mod in Southern California is to strip the rear wiper from the cars.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Clean the rear screen and put some glass polish on it, makes it easier to clean.
    alanclarkeau likes this.
  6. alanclarkeau
    7,045
    7,593
    Or Rain-X or similar products might help.
  7. Mendel Leisk
    41,852
    No spare either. :(
    And for this you pay extra. :confused:
    Prodigyplace likes this.
  8. bisco
    52,340
    i bet it can be done by a clever diy'er. drill a hole, add motor, linkage and wiper, change stalk. wiring is already there, that's the hard part.
  9. Prodigyplace
    12,655
    11,826
    Central Virginia
    No cargo cover either since mid 2017. I guess the added extra standard safety features weighed too much ? o_Oo_O
    I chose to get a Trim Two with spare & rear wiper. Part of the improved mileage rating for the Eco was due to the increased recommended tire pressure. I raised my tire pressure at no extra charge and, with a lot of highway driving, have averaged over 57 MPG over 30K+ miles.
  10. Mendel Leisk
    41,852
    I suspect there's something under-the-hood involved in the mpg rating increase, but it's kinda nuts to pay extra for a stripped-down version. I'm with you.
  11. Prodigyplace
    12,655
    11,826
    Central Virginia
    Actually they played the weight game using a Li-Ion battery and trimming extra weight to get into a lower weight EPA testing category.
    alanclarkeau and Mendel Leisk like this.
  12. Mendel Leisk
    41,852
    Yeah, l recall @Tideland Prius mentioning that. Akin to boxing in a lighter weight class. I guess at the end of the day (hate that expression) you can achieve better numbers with the Eco, it's not completely smoke-and-mirrors (that one too), but I'd take the accessories over the bleeding edge mpg status.
    Prodigyplace and alanclarkeau like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    There is a cargo cover;).
    It's just fabric:oops:.
    Definitely leaves something to be desired:censored:.
  14. alanclarkeau
    7,045
    7,593
    The biggest difficulty is that, even if the wiring is there - sometimes the software isn't set up to handle it - can be a bit tricky with some things like that these days. Not like the old days when a switch just closes a circuit to the motor or bulb.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Easiest solution arrived at.
    Mendel Leisk and alanclarkeau like this.
  16. Mendel Leisk
    41,852
    We don't get much snow/grime here on the wet coast, but fwiw, I use our rear wipers about as much as the fog lights. (Near zero.)
    alanclarkeau and krmcg like this.
  17. krmcg
    2,592
    2,392
    Whittier, CA
    In the 12 years I have been driving a Prius, I have intentionally turned the rear wiper on 1 time.
    kithmo and Mendel Leisk like this.
  18. alanclarkeau
    7,045
    7,593
    It's good that it's got an intermittent setting - I use it quite a bit - but only if it's raining:eek:.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You won't be able to drill it if it's toughened glass, which I suspect it is, it will shatter. The only solution to getting the hole is to swap out the glass for a higher trim one.
    The only time I use mine is to clear the screen if it's dirty when I'm too lazy to clean it before I set off.
    #19 kithmo, Apr 1, 2020
  20. Prodigyplace
    12,655
    11,826
    Central Virginia
    They removed that in mid 2017 including the needed mount points.
    Raytheeagle and alanclarkeau like this.
