How can I test the hybrid battery fan to see if it's working properly?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 5, 2020.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I just finished installing my HV battery, I would like to know if there is a way to see if the cooling fan is functioning properly
    Can I do this using torque?
    If so how?
    Is there a way to manually test it if that's not possible ?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Pretty sure my sig can offer guidance :whistle:
    Or try another app that supports overriding the HV battery fan (y)
    Raytheeagle likes this.
  3. Banksy
    415
    132
    I can't see your signature
    Also does this ducting look alright?
    That thing where the push pin thing goes in won't align
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  5. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    No, it doesn't, the face of the duct should be parallel with the battery. See if you can also align the two bolt holes (on the squarish part of the duct near the rear of the wheel arch) as well as the pushpin holes. That should help with the alignment.
  6. Banksy
    415
    132
    Alright sweet.
    One other thing too
    The temp sensor on the top of the battery is installed however I forgot to put those plastic clips in on the compression block for the wires.
    I could take the top off again as is but is it honestly a huge deal?
    How hot do those modules get?
  7. dolj
    dolj Senior Member
    7,651
    3,860
    Couldn't tell you, I haven't needed to dig that deep in the battery as yet.
    Maybe @strawbrad, @TMR-JWAP, @ericbecky, or one of the others that regularly work on batteries could answer that.
  8. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Those wires should fine as is.
    Not sure I've seen a pack get over 130F before, I try to keep mine under 100F when possible. Don't know about the internal temperature.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    If you're just talking about the white plastic, circular pieces that clip onto the black cross bar, I wouldn't worry about it. Keep them and next time you work on it (if ever) throw them back in. It wouldn't be worth your effort to take the battery apart to install them. It's not going to make a difference in performance.
  10. George W
    George W Senior Member
    911
    511
    San Antonio
    In the Dr. Prius app, under Special Features, you can over ride the temperature settings ( force the fan to start at a lower temp).
